wire clips with injectors if obd2 to obd1?
Old Jan 4, 2002 | 02:40 PM
cyan1de's Avatar
Default wire clips with injectors if obd2 to obd1?
i have a 1997 integra (OBD-II). i am going to use a hondata stage 1b or 2b depending on the amount of money i have when it comes time to purchase it. i read you need wire clips if you buy upgraded injectors (rc specifcally) but that's only for obd-II vehicles. would i still need to buy the clips since i'm reverting back to obd-I?
Old Jan 4, 2002 | 02:45 PM
redline's Avatar
Default Re: wire clips with injectors if obd2 to obd1? (cyan1de)
yes you do. cause you are still using your OBD-II engine harness and converting the harness at the ecu not the engine.
Old Jan 4, 2002 | 03:06 PM
Ri5e's Avatar
Default Re: wire clips with injectors if obd2 to obd1? (redline)
Get some off of a V8 or V6. Or find a 92-95 car and rip the clips off of them.
craig_shelman32
Nov 10, 2018 08:43 PM
turbodailydan
Aug 13, 2009 04:13 AM
D15Bbigred
Feb 10, 2006 01:33 PM
SupaFly_Honda
Jan 12, 2005 02:05 AM
redboost10
Jan 22, 2004 07:45 AM
