rc injector clips
Old Jan 21, 2004 | 10:19 AM
redboost10's Avatar
Default rc injector clips
im obd2 and am getting some rc 550cc sat injectors. now ive been told i can either use the rc clips or cut and rewire some obd1 plugs on my harness. which would you guys prefer?
Old Jan 21, 2004 | 10:21 AM
vtekthis's Avatar
you have to use obd 1 clips thats what i used!
Old Jan 21, 2004 | 10:35 AM
redboost10's Avatar
Default Re: (vtekthis)
i know i have to use the clips some way. but from what ive been told theres two ways: either buy the rc eng. clips $10 each or cut the obd1 stock plug-ins off a obd1 wire harness and wire those on my obd2 after i cut my obd2 ones off. will method 2 work
Old Jan 21, 2004 | 10:38 AM
b18bturbo's Avatar
Default Re: (tgh99si)
method 2 will work fine. all you really need is obd 1 clips if you cut them off early gen car and wire it up to new obdII wiring it will work just as good.
Old Jan 21, 2004 | 10:41 AM
redboost10's Avatar
Default Re: (b18bturbo)
ok thats what i wasnt sure of, method 2 but it does sound good. thanks guys.
Old Jan 21, 2004 | 01:17 PM
redboost10's Avatar
anyone willing to explain to me how the clips work? please
Modified by tgh99si at 11:02 PM 1/21/2004
Old Jan 21, 2004 | 02:02 PM
IN VTEC's Avatar
Same thing. They're both OBD-1 injector clips. Where's my stinkin' camera?
This is spare set of OBD-1 injector clips I have laying around since my car's already OBD-1.
Modified by IN VTEC at 5:14 PM 1/21/2004
Old Jan 21, 2004 | 02:03 PM
redboost10's Avatar
ive seen a pic of them at http://www.kteller.com. im not real sure how they work exactly. can someone explain. id rather use the clips than cut into my harness.
Old Jan 21, 2004 | 02:16 PM
redboost10's Avatar
are those just like the rc clips?
Old Jan 21, 2004 | 02:22 PM
ProEater's Avatar
Default Re: rc injector clips (tgh99si)
sorry for the quality....
rc clips (odb II)
Old Jan 22, 2004 | 01:09 AM
pissedoffsol's Avatar
25 Year Member
Default Re: rc injector clips (ProEater)
my obd1 clips didn't fit my rc 860s
bought some RC clips from wiredspeed and they go right on.
http://www.wiredspeed.com/wire...q=&Tp=
Old Jan 22, 2004 | 05:35 AM
IN VTEC's Avatar
Default Re: rc injector clips (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">my obd1 clips didn't fit my rc 860s
bought some RC clips from wiredspeed and they go right on.</TD></TR></TABLE>
Along those same lines, I tested my RC OBD-1 injector clips on a set of OBD-1 and OBD-2 OEM Honda injectors and they won't fit, but they fit perfectly on a set of RC 440's I had sitting in the room.
Old Jan 22, 2004 | 06:58 AM
b18bturbo's Avatar
Default Re: rc injector clips (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Along those same lines, I tested my RC OBD-1 injector clips on a set of OBD-1 and OBD-2 OEM Honda injectors and they won't fit, but they fit perfectly on a set of RC 440's I had sitting in the room.</TD></TR></TABLE>
the reason that is becuz there is tab in the factory injector that is different than the rc clips. Rc removes that tab and therefore it fits fine.
Old Jan 22, 2004 | 07:05 AM
Muckman's Avatar
Moderator in Chief
Default Re: rc injector clips (b18bturbo)
So the differences lie in the connector? Nothing to do with the wiring?
Old Jan 22, 2004 | 07:06 AM
b18bturbo's Avatar
Default Re: rc injector clips (Muckman)
for obd 1 vs obd 2 that is correct nothing with wiring or ohm rating or anything like that but the connector of the injector is totally different.
Old Jan 22, 2004 | 07:09 AM
HXMan's Avatar
ummmm....my saturated 550cc injectors don't look like they need an adaptor for obd2....I got a wire harness laying around, I will go see if they plug in.
Well, they don't. Damn, I was hoping they would plug in.
Does anyone make an OBD2 to OBD1 injector adaptor..that would be a nice thing so if you have to switch back to stock quickly you wouldn't have to unsolder everything.
Old Jan 22, 2004 | 07:23 AM
b18bturbo's Avatar
Default Re: rc injector clips (HXMan)
Does anyone make an OBD2 to OBD1 injector adaptor..that would be a nice thing so if you have to switch back to stock quickly you wouldn't have to unsolder everything.[/QUOTE]
the clips that you guys need are here.
ihave them but they are costly 60 a set
Old Jan 22, 2004 | 07:37 AM
b18bEG's Avatar
to me it looks as you could make your self a set from the pic above, how hard could it really be get some of each connectors and salder(sp?) in the wires, there are only 2 right? Depending on how though it would be to get the connectors
Old Jan 22, 2004 | 07:45 AM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">my obd1 clips didn't fit my rc 860s</TD></TR></TABLE>
Normally when you get to the bigger, low impedance injectors you'll need to run OE nonOBD connectors (or RC)... I personally like the RC's the best because of their ease in releasing... They're just as fast as an OBDII connector, where as nonOBD's and OBDI's require a pick to unclip the connectors... I just finished up converting Will's Rex's engine loom to OBDI just using nonOBD injector connectors for his new FI motor so I took some pics but guess what I forgot to bring home from school? The god damn USB cable... Oh well, I'll have Mike bring it home tomorrow... Just my $0.02
FINALLY even tho it's not that big of a deal...
Will's Rex's harness being converted to OBD1...
All done ready to be installed on his car...
The nonOBD injector clips for his RC900's...
Modified by Kataku2K3 at 2:45 PM 1/26/2004
Maleek
May 17, 2012 08:47 PM
turbodailydan
Aug 13, 2009 04:13 AM
jewpont
Jul 11, 2009 01:24 PM
00Red_SiR
Apr 27, 2008 08:19 AM
Black R
Nov 10, 2007 04:31 PM
