1 and 2 ply head gaskets
Old Dec 18, 2004 | 10:06 AM
RTW DC2R's Avatar
Default 1 and 2 ply head gaskets
Ive done some reading in the archives and there is some good info, but the archives were pretty old.
Im wondering if anyone that is running a 1 or 2 ply head gasket has had any long term problems since installing it? such as oil leaks or total gasket failure, and did you use copper spray when installing it? I wanna get the most out of my mainly stock motor (other than a few bolts ons) and I thought a head gasket would be a good addition when I get my block in a few weeks. I was thinking about just going with a stock gasket and taking out the middle layer as that seems to be the most popular and safest way to do it, other than spending $$$ on a 1 or 2 ply gasket. But like I said I didnt really see any recent follow up posts regarding this. I dont think I want to go 1 ply, probably just 2 ply to keep it safe.
Old Dec 18, 2004 | 04:36 PM
SlapSmak's Avatar
Default Re: 1 and 2 ply head gaskets (RTW DC2)
the 2 layer spoon gasket is actually a stock gasket with the center layer removed. It will raise compression by .2 I believe.
Old Dec 18, 2004 | 04:46 PM
RTW DC2R's Avatar
Default Re: 1 and 2 ply head gaskets (SlapSmak)
cool thanks i didnt realize the spoon was OEM but i guess i should have known better haha
any tips on removing the center section without ruining the gasket?
Old Feb 3, 2005 | 11:45 AM
RTW DC2R's Avatar
Default Re: 1 and 2 ply head gaskets (RTW Ryan)
Old Feb 3, 2005 | 11:51 AM
Mugen Mike's Avatar
I have over 87,000 miles on my Mugen 2 layer HG. Car has been ragged to **** and I have had no problems with it at all.
Old Feb 3, 2005 | 11:59 AM
RTW DC2R's Avatar
good to hear
now, can anyone tell me the "proper" way to turn my stock gasket into a 2 layer gasket or am I just gonna have to go for it myself and hope for the best.
Old Feb 3, 2005 | 12:13 PM
Teepo's Avatar
Default Re: (RTW Ryan)
I wouldn't cut corners on saving money to bump up the c/r......buy the damn gasket and enjoy
Old Feb 3, 2005 | 12:15 PM
MattD@Stoptech's Avatar
j00r timing will be off, will j00 be running adjustable cam gears?
Old Feb 3, 2005 | 02:22 PM
RTW DC2R's Avatar
yes
Old Feb 3, 2005 | 04:27 PM
GUILOTINE's Avatar
Kill Gil
there are little metal rings at all four corners that are easy to remove with needle nose pliers
I ran just the bottom layer on three different cars for years all the cars were tracked and street driven for years
Old Feb 3, 2005 | 04:30 PM
RTW DC2R's Avatar
just remove the rings and take out middle layer? then im guessing you cant put the rings back in so you just put the two layers back in loosely without the rings?
Old Feb 3, 2005 | 04:36 PM
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">just remove the rings and take out middle layer? then im guessing you cant put the rings back in so you just put the two layers back in loosely without the rings?</TD></TR></TABLE>
you dont have to reinstall them the head itself has two dowel pins that will align everything for you. I used copper spray BTW to help ensure the seal.
Old Feb 3, 2005 | 05:45 PM
RTW DC2R's Avatar
Default Re: (GUILOTINE)
thx
Old Feb 3, 2005 | 05:59 PM
Mike K's Avatar
i'm with guilotine on this one. just the bottom layer with copper spray works fine... assuming your head and block are in good shape.
i just drill the rivets out.. but pliers would work fine.
Old Feb 3, 2005 | 06:13 PM
GUILOTINE's Avatar
Kill Gil
Default Re: (Mike K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike K &raquo;</TD></TR><TR><TD CLASS="quote">i'm with guilotine on this one. just the bottom layer with copper spray works fine... assuming your head and block are in good shape.
i just drill the rivets out.. but pliers would work fine.</TD></TR></TABLE>
RTW DC2R's Avatar
cool, one layer it is then
thx again
GUILOTINE's Avatar
Kill Gil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">cool, one layer it is then
thx again</TD></TR></TABLE>
yes .4 raise
Old Feb 3, 2005 | 06:16 PM
.RJ's Avatar
.RJ
make sure j00 get the timing belt tension right - w/ a milled head and a thin gasket the belt will be l00se unless j00 leverage the tensioner a bit when setting tension
Pic courtesy r0d-knee
Old Feb 3, 2005 | 06:19 PM
RTW DC2R's Avatar
yeah ill make sure to triple check that. .4 raise in compression, is that too much for a stock ecu, vafc and stock injectors to handle? or should i just stick with a 2 layer? or i can just give chris a call.
Old Feb 3, 2005 | 08:41 PM
FSTASNTZ's Avatar
I no longer have the ITR, but I did run a spoon 2 ply gasket on mine for some time. There were no problems of any sort with leaks. I even ran the Spec C cams with the gasket and had head studs, not the OEM bolts. I probably put 15k on that setup before I did a total build up. The gasket was taken out and put on a friend's B16, with stock head hardware, and he never had a problem.
And no, no copper spray was ever used.
Jason
Ruben19
Apr 27, 2006 08:37 AM
WEPN R
Oct 8, 2002 06:50 PM
schwett
Apr 18, 2002 04:19 PM
therealnapster
Sep 10, 2001 01:32 PM
