What is the stock timing?
Old Jan 4, 2002 | 02:13 PM
JSpecwest's Avatar
New User
Default What is the stock timing?
What is the stock timing for a Type R and how do I set it? I have a timing light and I know you move the distributor back and forth but how do you know how far to go? I see the red and white marks on the pulley but what do they mean? Also, does pulling the distributor towards you retard or advance timing? TIA...
Old Jan 4, 2002 | 02:22 PM
AWDSOME's Avatar
Default Re: What is the stock timing? (JSpecwest)
Stock timing is 16 +/- 2 and the following post helps explain how to do:
https://honda-tech.com/zerothread?id=104863
[Modified by Hyper165, 6:22 PM 1/4/2002]
[Modified by Hyper165, 6:23 PM 1/4/2002]
Old Jan 4, 2002 | 02:29 PM
Ibuprofen's Avatar
Default Re: What is the stock timing? (Hyper165)
stock timing is 14
Old Jan 4, 2002 | 02:36 PM
B2FiNiTY's Avatar
!?!? I'm pretty sure it's 16.
[Modified by B2FiNiTY, 3:36 PM 1/4/2002]
Old Jan 4, 2002 | 02:39 PM
Ibuprofen's Avatar
Default Re: What is the stock timing? (B2FiNiTY)
hmm..i asked around, and alot of ppl said theres were set at 14 degrees. when i did the advance timing, mine was also set at 14 degrees..
Old Jan 4, 2002 | 02:40 PM
B2FiNiTY's Avatar
Default Re: What is the stock timing? (ITYP3R)
You advanced it to 14?? Or should I say retarded it to 14.
Old Jan 4, 2002 | 03:02 PM
Ibuprofen's Avatar
nono, when i checked the timing, it was set at 14 degrees stock. sorry bouit that
Old Jan 4, 2002 | 03:06 PM
austrian type-R's Avatar
DAMN..... I´ve a shop manual and it says 16 +/- 2 degrees. Make sure you have your idle speed at 750 +/- 50 rpm.
Old Jan 4, 2002 | 03:51 PM
Jason's Avatar
stock timing IS 16...but the +/- 2 still falls into spec...YOURS may have been 14, but it's supposed to be 16
Old Jan 4, 2002 | 04:07 PM
BodyKits NW's Avatar
14-16 is fine as long as your idle speed is down. Too bad you don't got the stock hood Jared. I believe it would give you your settings on there.
Old Jan 4, 2002 | 04:15 PM
JoshRambo's Avatar
Default Re: What is the stock timing? (BodyKits NW)
i'll go with the others and say it is set at 16. i adjusted mine to 18 as most have done
i used the c-speed racing directions. they are right on
http://www.c-speedracing.com/howto/timing/timing.html
Old Jan 4, 2002 | 05:42 PM
fitzuni's Avatar
New User
Default Re: What is the stock timing? (Gravity)
mine waz 13 deg ,now it on 16, run great 14.62 @94.98
Old Jan 4, 2002 | 06:34 PM
Ibuprofen's Avatar
Default Re: What is the stock timing? (fitzuni)
i'm curious..what if your idle speed was not at 750 +- 50 when adjusting the timing? will it run higher then 18 in that case?
Old Jan 4, 2002 | 08:11 PM
TypeRvtec18's Avatar
New User
mine is set at 14 stock
Old Jan 4, 2002 | 09:03 PM
GRM Scott's Avatar
25 Year Member
Default Re: What is the stock timing? (TypeRvtec18)
Stock is 16 +/- 2 according to helm for the B18C engines. Setting your timing to 18 is a great way to get free horsepower on near-stock B18C5s, i gained 3-5 hp across the powerband going from 15.5 to 18.
Old Jan 5, 2002 | 12:08 AM
SoCal ITR's Avatar
Default Re: What is the stock timing? (Aleph)
I was under the impression that we were set to 16 too..... I want an advance
Chris, who wonders if he can cash in on the raincheck for a tming advance at the next meet...
Old Jan 5, 2002 | 12:15 AM
Bloodwynch's Avatar
Stock is meant to be 16, but i've found my to be about 14.5 from the factory.
I've now set mine at 17.5 'ish and i feel it's slightly more responsive.
Old Jan 5, 2002 | 02:01 AM
SoCal ITR's Avatar
Default Re: What is the stock timing? (Fuzznuts)
I think that at least one SoCal fool has one....... Anyone want to step forward on this?
FlewByU352
Nov 13, 2010 07:27 PM
rice a roni
Aug 25, 2005 07:17 AM
dubnine
Sep 16, 2002 01:35 PM
Tx92AccordExD
Jul 22, 2002 11:13 PM
rioninja
Aug 4, 2001 05:48 AM
