How do you like ACL bearings? Yay or nay?
All I can say is I've only heard good things about them. They are currently in my spare sohc motor, but it isn't needed yet so i can't really give you a review.
I will say that when I plastiguaged them, they did run in spec for the motor. Guess I got lucky or something
I am about to build my C1 with them. Got a good deal from Earl
. Look up his name and im sure you will see a lot about acls. You know, in another thread someone said that you dont need to platiguage them. I cant remember if earl said that or not. Anyway pm him and he will tell you a lot about them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioViRs »</TD></TR><TR><TD CLASS="quote"> You know, in another thread someone said that you dont need to platiguage them. </TD></TR></TABLE>
Not checking tolerances is asking for disaster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">
Not checking tolerances is asking for disaster.</TD></TR></TABLE>
Using them also in my freshly rebuilt motor
the machine shop installed them and checked for clearances and resized the big end of the rod to get perfect clearnces
i rock them in the D16A6 i built for a friend, came out to almost perfict specs on the plasigauge. i give them a
i know that and plan on doing it when i build my motor. Its just that people say they are one size fits all so there is no need to do it. I dont know, take a look at this link.
https://honda-tech.com/zerothread?id=1083159
Earl reccommended the ACL's for my 600whp b16 build. . .
And that's what I put in the motor
And earl also mentioned that he VERY RARELY has problems with the clearances of ACL's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti444 »</TD></TR><TR><TD CLASS="quote">whats main reason people choose the acl over oem ?</TD></TR></TABLE>
Availability
Availability
I PERSONALLY wouldn't use anything other than OEM after checking all tolerances and ordering the proper bearing size for the application.
However, I have heard no bad things about ACLs. I suppose if you check the tolerances and order the proper bearing, you should be ok, but why not just go ahead and use O.E.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">I PERSONALLY wouldn't use anything other than OEM after checking all tolerances and ordering the proper bearing size for the application.
However, I have heard no bad things about ACLs. I suppose if you check the tolerances and order the proper bearing, you should be ok, but why not just go ahead and use O.E.?</TD></TR></TABLE>
There was a period in which the OEM bearings were on backorder and the wait would be forever. Not sure if this is still the case. That may be a deciding factor for some to go ahead and use aftermarket bearings for their respective rebuilds. Price can be another attributing factor in the decision to go with OEM or aftermarket.
Red D Dragon
19
Dec 1, 2004 03:03 PM
ThirdGenLSR209
Jan 23, 2004 02:53 PM
