Sparco Harness bar and the like (and some R patronizing).
Old Dec 17, 2004 | 11:14 PM
EMphaticONE's Avatar
Default Sparco Harness bar and the like (and some R patronizing).
So I figured I would ask this question in the type-R forum since the majority of R owners are knowledgeable via the obligation an R. Is the Sparco (or any other harness bar) a safe/certified way to add racing harness, or is it a necessity that you wrap the harness around a cage?
Old Dec 18, 2004 | 12:13 AM
01-0720's Avatar
Default Re: Sparco Harness bar and the like (and some R patronizing). (pearlblueb16)
if the bar it self and the harnesses are mounted correctly it is safe to an extent, your still at risk in a rollover, if you roll in stock belts you can move your head to the side or move so you head isnt crushed if the roof caves in, if you have harnesses on you wont be able to move at all in a roll over and you might smash your head on the roof in a roll over
at least get a roll bar, ie kirk, autopower, its a 4 point style two points behind the seats with a hoop and two bars that go back to the trunk, the best and safest whould be a full cage basically same as 4 point roll bar, but has bars that go over the door way down to the front floor by the dash and some have bars that go across the door, there all different
you just gotta ask yourself what your gonna do with your car, autox mild spirited driving, show ***, you could get away with the harness bar and some 4 point harnesses
hpde, track events more serious racing, either the rollbar whould be enough or if you wanted you could go with the full cage
sorry for the long post its 4 in the morning and i cant sleep, please correct me if i gave any wrong information
and of course if your going all out racing , youd def want the full cage, but if your at this level you whouldnt be asking about harness bars
Old Dec 18, 2004 | 02:11 AM
nightrider's Avatar
ask yourself what you will use your harness bar for. if you autocross, i would say it is an advantage with little worries because the likelihood of a rollover is slim. i would not use the harnesses on the street however. finally, if this is for the tracks, rollbar definitely.
Old Dec 18, 2004 | 06:48 AM
.RJ's Avatar
.RJ
Old Dec 18, 2004 | 07:00 AM
Opie's Avatar
Wait, I thought if you had a 4 pt you had to remove your back seats?
Maybe it's just because all the cars I have ever taken notice to with rollbars have been R-speed stunners
Old Dec 18, 2004 | 07:03 AM
boostjunkie757's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Wait, I thought if you had a 4 pt you had to remove your back seats?
the numba one stunna...
WHAT WHAT WHAT.
Old Dec 18, 2004 | 07:13 AM
.RJ's Avatar
.RJ
Default Re: (opie)
Old Dec 18, 2004 | 07:18 AM
1GreyTeg's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Wait, I thought if you had a 4 pt you had to remove your back seats?</TD></TR></TABLE>
Well, the addition of the rollbar makes sitting in the back seat both dangerous and uncomfortable.
Not to mention when you remove all the junk in the rear there is quite a bit more room to carry other junk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Maybe it's just because all the cars I have ever taken notice to with rollbars have been R-speed stunners
Yep, We sTuNnAz Yo!
Old Dec 18, 2004 | 07:20 AM
Opie's Avatar
lol thanks
I want one, but need more money to get other Rollbar related goodies
Old Dec 18, 2004 | 07:26 AM
Jon D's Avatar
Default Re: (opie)
I need to learn to need a cage first
Old Dec 18, 2004 | 07:31 AM
Chris F's Avatar
Default Re: (B18C-Rsi)
https://honda-tech.com/zerothread?id=1088387
There's a lot of opinions on this.
Old Dec 18, 2004 | 08:24 AM
MissMyHonda's Avatar
harness bars are an excellent way to get good driver position and support while auto-xing. Harness bars ARE NOT safety devices and should not be used on the street or on the track. If you roll a car and you're wearing harnesses w/o a rollbar/cage you're going to be at more of a risk than you would be with a 3 pt seat belt.
Old Dec 18, 2004 | 12:26 PM
Haleiwa-Brando's Avatar
Default Re: (JoesTypeS)
When I first got my Type R, I had installed the Sparco Harness bar with Takata Harnesses. Due to some VERY serious safety issues that many of you pointed out, I quickly realized how dangerous those things really are. For starters...puting friends in the back seat is absolutely off limits. Second, you are seriously puting yourself at risk of serious injury or death, in the event that you were ever in a roll over.
What is funny is that for the price Sparco is charging for that harness bar, you can buy yourself an NHRA certified 6 point cage which will actually function properly and save your life.
Regardless if you go with a proper roll bar or cage or that shitty little harness bar, do yourself a favor and take the back seat out so you can do a proper job.
I'm actually in the process of reevaluating my current roll bar to make it much more safer since I'm going up in HP. I may just replace it with a six-point cage.
Aloha,
Brandon
tdperf
Honda Civic (2006 - 2015)
Jan 15, 2007 08:43 AM
onePOINTsix
Welding / Fabrication
Jan 4, 2005 03:10 AM
Sport_Injected
Aug 21, 2004 04:28 PM
Powered by Honda
15
Mar 5, 2004 06:54 AM
Outsane
Oct 31, 2003 10:05 AM
