I just bought 97 lude, but :((
Old Dec 17, 2004 | 07:26 PM
DeltaX's Avatar
Default I just bought 97 lude, but :((
hey
I just bought Lude 97 5 spd,,, 88k
me and my buddy test drove it yesterday, it grinds at 5th geat and sometimes 3rd. then I took it to my friend, hes mechanic tho, he said dont buy it.
Today, my other friend he used to work at Acura drove the car and then took it to Certified Tranny shop , they both said tranny is good, just get me Synchromesh fluid. Whatcha guys thinking ?
Old Dec 17, 2004 | 07:31 PM
spoolude's Avatar
Default Re: I just bought 97 lude, but :(( (DeltaX)
change the synchromesh fluid and u should be fine mine did that and i change the fluid and its fine..
Old Dec 17, 2004 | 07:35 PM
DeltaX's Avatar
Default Re: I just bought 97 lude, but :(( (spoolude)
i hope man,
im so worried !!!
SHhh__VTEC's Avatar
where can you get the cynchromesh fluid at?? How much are you suppose to put back in?? I never changed this before and I think it's time to do so.
Old Dec 17, 2004 | 07:58 PM
DeltaX's Avatar
Default Re: (SHhh__VTEC)
I still didnt change tranny fluid
tomorrow, I will
some ppl said synchromesh will make the grinding clear
now im confused
Old Dec 17, 2004 | 08:00 PM
PreludeX24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHhh__VTEC &raquo;</TD></TR><TR><TD CLASS="quote">where can you get the cynchromesh fluid at?? How much are you suppose to put back in?? I never changed this before and I think it's time to do so. </TD></TR></TABLE>
search!
but yeah, you can get synchromesh from o'reillys or autozone. it should be around $5 per quart and you're going to need about 2 quarts, but i'll get 3 just in case.
you're going to have to get underneath the car to do this, and best to buy a little pump to pump the fluid into the tranny.
once your underneath the car look on the side of the tranny facing the passenger wheel. you should be able to see 2 different looking bolts than the rest of them. The one on the top is the filler hole (where you fill the fluid up at), and the bottom one which has a square middle thingy is the drain hole (where you drain the fluid).
Best way to do it is first see if you can remove the filler bolt first, because you wouldn't want to get stuck with a drained tranny and you can't get the filler bolt off to refill it. A little bit of fluid should come out once you get the filler bolt off, then next thing get the drain bolt out (FYI fluid comes out pretty far).
Let it sit for a while to get it mostly drained, then put the drain bolt back on. Get your pump and stick the end of the tube into the filler hole and start pumping. Keep pumping until the fluid reaches the filler hole, just enough where a little bit comes out. The filler hole is the level of the amount of fluid you're suppose to have in there. After that put the bolt back on and you're set! You usually don't feel any difference right away, it took me the next day to really feel the smoothness.
Old Dec 17, 2004 | 08:50 PM
SHhh__VTEC's Avatar
That sounds like changing the tranny fluid. Are they both the same or is the synchromesh an additive?? =P
I would've searched but since this thread was on this subject, I thought I'd ask anyway. My fault if it gonna cause any flames. hehe
Old Dec 17, 2004 | 09:56 PM
PreludeX24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHhh__VTEC &raquo;</TD></TR><TR><TD CLASS="quote">That sounds like changing the tranny fluid. Are they both the same or is the synchromesh an additive?? =P
I would've searched but since this thread was on this subject, I thought I'd ask anyway. My fault if it gonna cause any flames. hehe</TD></TR></TABLE>
haha..synchromesh is a tranny fluid, not an additive. most people get the GM synchromesh fluid, but i couldn't find any except for the Pennzoil synchromesh. I'm not sure if they're both the same or not buy the guy at o'reillys told me their almost basically the same stuff. I went to a couple of auto stores looking for the GM brand but no luck. Only Pennzoil =/
Old Dec 18, 2004 | 12:01 AM
Integr8d's Avatar
Just so you know, synchros are what get your clutch and tranny to play nicely. If you ever lose a synchro, you'll know it. If you ever lose a drop bearing, you'll know it. And if it's time to replace your tranny fluid... well you do know it.
My advice is to take it to Jiffy Lube. You said you just got the car right? And you probably have no idea when the last time the fluids were done? It'll cost a little more. But I'd recommend having them drain the old stuff, then flush the tranny, and then put in whatever you want. There's really no reason to do your own fluids. Those places carry their own full syn oils. And to be totally honest, how much of a difference do you think there is between Redline and Mobil and Penzoil? I'll tell you the difference... Adam Sawaratari uses Redline... because that's who sponsors him and he gets it for FREE. So Adam is going to say, "Use Redline. I do!"
Peace.
Old Dec 18, 2004 | 03:22 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: I just bought 97 lude, but :(( (Integr8d)
I warned you about the car!
Replacing the tranny fluid will only temporary fix the problem.
Old Dec 18, 2004 | 06:17 AM
prelude1897's Avatar
I bought some from a GM dealership. I think it was about $10 a bottle or somewhere close to it....
Old Dec 18, 2004 | 08:22 AM
Matgallis's Avatar
Default Re: I just bought 97 lude, but :(( (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">I warned you about the car!
</TD></TR></TABLE>Exactly, those syncros will need some lov'n soon.
Old Dec 18, 2004 | 08:39 AM
* B A N N E D *
Default Re: I just bought 97 lude, but :(( (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">Exactly, those syncros will need some lov'n soon.</TD></TR></TABLE>
and his wallet will hate him forever.
Old Dec 18, 2004 | 09:02 AM
jnet's Avatar
eh...can get a whole new tranny for $300.
Old Dec 18, 2004 | 09:10 AM
matix's Avatar
Default Re: I just bought 97 lude, but :(( (jnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeX24 &raquo;</TD></TR><TR><TD CLASS="quote">haha..synchromesh is a tranny fluid, not an additive. most people get the GM synchromesh fluid, but i couldn't find any except for the Pennzoil synchromesh. I'm not sure if they're both the same or not buy the guy at o'reillys told me their almost basically the same stuff. I went to a couple of auto stores looking for the GM brand but no luck. Only Pennzoil =/</TD></TR></TABLE>
The penzoil syncromesh is what you want. It the same as gm syncromesh but way cheaper.
Old Dec 18, 2004 | 09:27 AM
Boarderx192's Avatar
Default Re: I just bought 97 lude, but :(( (matix)
I thought the best fluid for our cars transmissions was from Honda. Ive heard that everything else is to thin and doesnt coat as well. True?
Old Dec 18, 2004 | 09:37 AM
jaxx4k's Avatar
Default Re: I just bought 97 lude, but :(( (Boarderx192)
my stock h22 tranny grinds durin hard shifting but after GMS it shift it it was brand new... my accord tranny does the same thing now is reall good... GMS
Old Dec 20, 2004 | 09:33 PM
DeltaX's Avatar
Default Re: I just bought 97 lude, but :(( (jaxx4k)
well, the car was services regularly at jiffy lube before I bought it, but I did use GM synchromesh, it just made it worse, I went back to jiffy lube and got me regular 10-30. I m just double clutching for now to avoid the grind into 5th gear. I dunno why we r makin hella deal outta this grind. I used to have cars that grind all the time at several gears and they last forever. All what im asking , Does double clutching wont hurt it anymore and can I live with that for while [with double clutching , no grind] . im takin my car tomorrow to ATSI transmission place in Lawrence KS, to gimme quote how much it cost to replace the synchros ,....
no luck , just bought it and havin problems,
but im still happy, I whooped Eclipse 2003 GTS dude today,
Old Dec 20, 2004 | 10:36 PM
Matgallis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeltaX &raquo;</TD></TR><TR><TD CLASS="quote">but im still happy, I whooped Eclipse 2003 GTS dude today, </TD></TR></TABLE>Lol theres your problem
Old Dec 21, 2004 | 06:07 PM
funkmasterchipz's Avatar
dude 2003 gts eclipses are slower than a ford taurus...sorry for the flame but try a 92 GSX or TSI they will rip u to pieces........anyways i suggest getting the tranny looked at...getting a synchromesh fluid is like getting that engine honey stuff...just a quick fix
Old Dec 21, 2004 | 06:54 PM
Mykizism's Avatar
um...jiffy lube is the worst place on earth.
Old Dec 21, 2004 | 08:27 PM
lakerschamp2000's Avatar
exactly what happened to my car.
Old Dec 21, 2004 | 10:53 PM
DeltaX's Avatar
Default Re: I just bought 97 lude, but :(( (lakerschamp2000)
they gave me horrible estimate, anyone around KS/MO can help , lemme know
its the darm synchros, im double clutching for now, till I do somethin
Old Dec 22, 2004 | 10:05 AM
DeltaX's Avatar
hey jnet
where from ? Milage ? type of tranny ?
aries331
Dec 1, 2007 01:13 PM
St3v3
Dec 4, 2006 04:37 PM
r0dxx
Jun 18, 2005 10:36 PM
Jon D
12
Jan 22, 2004 07:07 AM
ooooitswilson
18
Sep 15, 2003 02:09 PM
