Anyone know which one of these magnaflow universal converters will properly fit my car?
Old Dec 17, 2004 | 05:23 PM
hondaracin24's Avatar
Default Anyone know which one of these magnaflow universal converters will properly fit my car?
http://www.performancepeddler....ame=2
They all differ in length but Im not sure which one will correctly fit my car...
Old Dec 19, 2004 | 02:28 PM
Default Re: Anyone know which one of these magnaflow universal converters will properly fit my car? (hondara
I take that as nobody knows....
Does anybody atleast know the dimensions of the stock cat converter for my 94 Accord...
Old Dec 19, 2004 | 09:46 PM
Carolina Fried Rice's Avatar
I believe its 16" in length, I may be wrong though. The easiest solution would be to replace the cat with a straight pipe.
Old Dec 20, 2004 | 01:31 PM
And doesnt a straight pipe reduce backpressure in the car and make it a lot louder? Because if that would be the case Id rather stick with stock which is why im looking for aftermarket other than the straight pipe solution....
Old Dec 20, 2004 | 07:51 PM
As long as you are running an exhaust that isn't bigger than 2.25" there should be no worries with backpressure, you have plenty. IMO aftermarket cat's = waste of money. Just get a "high-flow cat" from ebay or something, they are actually resinators (which wont make it as loud as a straight pipe). If you are worried about passing emissions inspections, ignore everything I've said.
If you get the magnaflow, let us know the results.
Old Dec 21, 2004 | 08:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TSAF22B1 &raquo;</TD></TR><TR><TD CLASS="quote">As long as you are running an exhaust that isn't bigger than 2.25" there should be no worries with backpressure, you have plenty. IMO aftermarket cat's = waste of money. Just get a "high-flow cat" from ebay or something, they are actually resinators (which wont make it as loud as a straight pipe). If you are worried about passing emissions inspections, ignore everything I've said.
If you get the magnaflow, let us know the results.</TD></TR></TABLE>
I wanted to get a high flow cat from ebay but I heard that they work for about a couple of months and then afterwards they fall apart on you. Part of the reason I wanted a new converter is because the stock one is getting old and I figured instead of replacing it with another stock one why not upgrade and get one thats les restrictive but wont fall apart on you in a couple of months if you know what I mean....
Old Dec 21, 2004 | 10:18 PM
Thats true in some cases about the ebay cat. I had mine on my last accord for almost a year with no problems... but I've heard of them breaking at the welds etc. I've never heard anything bad about the magnaflow's, so I'd say go for it. btw, have you figured out which one fits yet?
Old Dec 23, 2004 | 07:21 AM
Im still not sure yet. Im going to give them a call today......
Old Dec 23, 2004 | 11:55 AM
EX-JAY's Avatar
Are you aware that emmisions related components are covered for an extended period from honda; I believe is like 12 years.
Old Dec 23, 2004 | 12:23 PM
rudeman85's Avatar
I just bought a high flow replacement cat on my '94 accord and I believe I got it @ performancepeddler.com Call them and oh god! did I get a good deal.
Mo_HCC
Jun 15, 2005 06:29 PM
JustHere4ADay
Apr 6, 2005 11:20 AM
not.sponsored
Aug 7, 2004 03:54 AM
07
Apr 5, 2004 09:55 PM
yellowmonkeyboy
Jul 2, 2003 03:23 PM
