What OEM piston in gsr block
What oem piston should I use in my gsr block with pr3 head...I'll be running s2s2 vavletrain. I'll be running 93 octane and be tuning with crome. Should I use CTR/JDM ITRwith 2 layer gasket/ JDM b16. I want to hit 200 whp or more with tuning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">jdm b16 p30's would work well and yield a nice compression</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com »</TD></TR><TR><TD CLASS="quote">the flat quench pads of the gsr head and matching piston offered a lot more detonation resistance than the b16 recessed pads. </TD></TR></TABLE>
whats this guy said.
if you're using a b18c1 head, figure out what compression ratio you want, and go from there. if that means a thin headgasket and b18c5 pistons, or whatever...
also realize that the flat top pistons w/ small chamber make for a better flame front, and more complete burn. b18c1 head rocks. look up my old post of my b20z destroker. it was running a b18c1 head and was the same size as an LS motor. 212.8hp and 143.8tq @ the wheels.
bottom line is.. figure out your gal.. and go from there.
p73-00's.....ahhh i love dem jdm itr's. have that and the jdm itr cams. put down 170whp and 120wtq untuned. everything else is stock...
heres a good site for cr caculations
<A HREF="http://www.c-speedracing.com/howto/compcalc/compcalc.php
" TARGET="_blank">http://www.c-speedracing.com/h...php
</A>
</A>
theneil
Jan 15, 2006 09:17 AM
