i cant get my hood open
Old Dec 17, 2004 | 09:29 AM
Mr.E.G.'s Avatar
Default i cant get my hood open
my goddamn hood latch cable has disconnected it self from the mechanism under the hood. i am supposed to begin my motor swap in a few hours.
any suggestions?
Old Dec 17, 2004 | 09:30 AM
Mr.E.G.'s Avatar
why is it that if i help someone with a motor swap in thier car it practically jumps right into the engine bay, but when i do something to my car, its a ******* catastrophy. my first motor swap was surrounded by similar circumstances
Old Dec 17, 2004 | 09:31 AM
Lee_Delso's Avatar
Default Re: i cant get my hood open (Mr.E.G.)
Go to the front of car, reach under your bumber, or else try going through the driver fender.
Old Dec 17, 2004 | 09:35 AM
ABK's Avatar
ABK
Default Re: i cant get my hood open (Lee_Delso)
yep just pull on the cable from underneath the bumper, or take pliers and pull on the remaining cable that you got.
Old Dec 17, 2004 | 09:36 AM
Mr.E.G.'s Avatar
i can see the part of the latch that slides side to side and i can move it with a screw driver but it is not popping up.
the cable has come loose at the latch not inside the cab
Pioneer162's Avatar
Default Re: (Mr.E.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">why is it that if i help someone with a motor swap in thier car it practically jumps right into the engine bay, but when i do something to my car, its a ******* catastrophy. my first motor swap was surrounded by similar circumstances</TD></TR></TABLE>
lol I know what you mean...
Old Dec 17, 2004 | 10:03 AM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote"> but when i do something to my car, its a ******* catastrophy. my first motor swap was surrounded by similar circumstances</TD></TR></TABLE>
LOL...you don't want to hear about my teg then! I just went to put on a adjustable rear control arm on my integra and one bolt is frozzen. After it finally starts turning, the insert in the frame snaps loose. $300 bodyshop fix to be able to put a new thread insert in the frame. (had to cut a hole in the trunk to get to the frame)
Old Dec 17, 2004 | 10:38 AM
rasinhell's Avatar
use a sawzall and simply slice the car open.
Old Dec 17, 2004 | 11:30 AM
Sour Diesel's Avatar
Default Re: i cant get my hood open (roboedar)
Xs 2 ^^^^^
Old Dec 17, 2004 | 11:44 AM
arielb1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">i can see the part of the latch that slides side to side and i can move it with a screw driver but it is not popping up.
the cable has come loose at the latch not inside the cab</TD></TR></TABLE>
Is it possible that when you move the latch with a screwdriver and it is not popping up is because you need to pull up on the hood at the same time? Just my 2 cents. I hope I am right, though.
Old Dec 17, 2004 | 11:49 AM
menkio's Avatar
Default Re: (arielb1)
just take off the spash guard go up from under the car, use a small stick, screw driver and push the lock in, did it once.. real easy
Old Dec 17, 2004 | 12:27 PM
Mr.E.G.'s Avatar
i will put it on a lift after work and see what i can come up with.
arielb i tried lifting it, but i believe that there is a piece that allos vertical movement and then the piece that i can see that moves side to side. but thanks for your suggestion
thank you menkio
Old Dec 17, 2004 | 12:42 PM
Mr.E.G.'s Avatar
marauder,
i have been in that boat before. when i did my rear brake conversion i did it in a friends driveway. the camber on my car was all screwed and and i couldnt figure out why. i later found out that the rear trailing arm was bent but at the time i just assumed that i was doing it wrong. so i took off the upper control arm and put it back on about a dozen times. well, it was getting late i was blocking my frieds dads drive way and he was getting pissed because he had some appointment to go to. in a last desperate attempt i put it back together again (it was dark by now)
and my friends dad gets frustrated and he taked the rachet from me and muscles the upper control arms back on. a couple days go by and i find out that he stripped the **** out of it and i have to helicoil it.
when i work on other peoples cars it's like the clouds part and jesus christ himself descends on a diamond covered chariot handing out chocolates and teddy bears.
but when its my own car... well lets just say that i am starting to think that jesus is must be a nascar fan.
Old Dec 20, 2004 | 05:25 AM
Mr.E.G.'s Avatar
i got it open thanks honda tech
Old Dec 20, 2004 | 07:56 AM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">well lets just say that i am starting to think that jesus is must be a nascar fan. </TD></TR></TABLE>
Nooooooooooo!!! :D
Glad ya got er open
Old Dec 20, 2004 | 08:17 AM
Cray91's Avatar
it should have been super easy to get in there with it up in the air.
dirtyharryhatch
Feb 25, 2008 11:13 AM
dopefeen
Oct 14, 2007 01:04 PM
madmanmulligan
May 21, 2006 09:32 AM
GroundZer0
May 22, 2003 03:43 PM
sidewayz
Mar 12, 2003 07:28 PM
