Which H/G for over 1.5 CR drop ?
Old Dec 17, 2004 | 08:53 AM
X2BOARD's Avatar
Default Which H/G for over 1.5 CR drop ?
Who's making a reliable headgasket that can drop compression as much as 1.5 points OR more ? If anyone makes it...
I am running high CR and contemplating boost, but I'd like to get down closer to 10:1. If no one makes a gasket that can drop that much... is it safe/possible to stack the gaskets for a bigger drop ?
Old Dec 17, 2004 | 09:06 AM
TurboJesse
Guest
Posts: n/a
Default Re: Which H/G for over 1.5 CR drop ? (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">Who's making a reliable headgasket that can drop compression as much as 1.5 points OR more ? If anyone makes it...
I am running high CR and contemplating boost, but I'd like to get down closer to 10:1. If no one makes a gasket that can drop that much... is it safe/possible to stack the gaskets for a bigger drop ?</TD></TR></TABLE>
I wouldn't go more than 1 full pt. You are going to ruin your quench area and possibly have sealing problesm.
Old Dec 17, 2004 | 09:11 AM
X2BOARD's Avatar
Default Re: Which H/G for over 1.5 CR drop ? (Mpir3)
Sealing problem ? So these gaskets don't work well ?
Old Dec 17, 2004 | 09:46 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">Sealing problem ? So these gaskets don't work well ?</TD></TR></TABLE>
I'd be more worried about the lack of a decent quench area, coupled with the relative high CR and you've got a nice recepie for bad things.
Old Dec 20, 2004 | 05:17 AM
X2BOARD's Avatar
Default Re: Which H/G for over 1.5 CR drop ? (VTC_resurected_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_resurected_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">
I'd be more worried about the lack of a decent quench area, coupled with the relative high CR and you've got a nice recepie for bad things. </TD></TR></TABLE>
You now YOU are against it ? The last of the little turbo devils on my shoulder ? I don't know you anymore man....
Well I was considering this, my compression is 11.6:1 (there I said it in public)... I was considering a B16 head instead of the GSR so I'd lose close to 0.2 ? Ok, now it's down to 11.4:1... so is there a decent HG to drop that # to something that I can consider boosting ?
VTC, we talked about this... I only want about 6psi or so.
X2 (Trying to avoid building ANOTHER motor)
Old Dec 20, 2004 | 06:01 AM
VTC_CiViC's Avatar
I already told you man, a conservative tune with a simple turbo setup = 300whp easily. Go look at what those B18C5's put down with like 7-9psi, it's ridiculous!
Old Dec 20, 2004 | 06:15 AM
X2BOARD's Avatar
^^ Yeah, but are you talking about my setup with a thick H/G ? I really don't want to even dream about it on my current CR. If so... what should I try to get it down to ? Right below 11:1, like the c5's ? (10.8, right ?)
Old Dec 20, 2004 | 07:02 AM
93H22ACX's Avatar
cometic has a hg that will drop the compression down 1 point. its like $125+ for one.
Old Dec 20, 2004 | 10:17 AM
AzG35's Avatar
Default Re: Which H/G for over 1.5 CR drop ? (93H22ACX)
I used the .074 MLS gasket and its worked fine. I had 12:1 CR and I'm down to about 10.5:1 now.
Old Dec 20, 2004 | 10:19 AM
X2BOARD's Avatar
Who's MLS ?
Old Dec 20, 2004 | 10:25 AM
Gravy's Avatar
Default Re: (X2BOARD)
its cometic. MLS stands for multi layer steel.
Old Dec 20, 2004 | 10:26 AM
SOHC_MShue's Avatar
just get a gasket that drops it a little bit and run high compression + low boost. You will still be fast as **** on low boost.
Old Dec 20, 2004 | 10:41 AM
X2BOARD's Avatar
Default Re: Which H/G for over 1.5 CR drop ? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">just get a gasket that drops it a little bit and run high compression + low boost. You will still be fast as **** on low boost. </TD></TR></TABLE>
Yeah, but too low and any decently sized turbo will be struggling to flow.... I don't want to have to spool all they way up top and I don't want to run a 14b.... lol.
So at what point gasket wise should I worry about the quench area being 'violated' ?
ojasia
Jul 13, 2014 08:24 PM
g2turbo
Apr 18, 2005 04:00 AM
madman604
Jun 2, 2003 11:09 AM
GSRacer
Oct 15, 2001 08:09 AM
joe pagolac
Aug 21, 2001 09:02 AM
