What type of transmission Fluid?
I have a 1989 civic, 4 speed. I would like to change the transmission fluid and i'm not sure what kind to get, does anyone know what kind it uses and how much to use. And is there a filter i have to change?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson »</TD></TR><TR><TD CLASS="quote">i run honda mtf</TD></TR></TABLE>
I would first get some Sea Foam trans cleaner and run that in the tranny with the old oil for about 15 min of 'spirited' driving. Then drain old fluid, refill with whatever you choose - I chose Castrol GTX 10w30 Cause I live by that brand - and then I used some Lucas Oil Stabilizer. With that combination I get slick shifts that always feel great and I've used this combination every 5k miles. BTW my car see's 7100 rpms quite often daily. - Darrell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro »</TD></TR><TR><TD CLASS="quote">Penzoil Synchromesh (replaces GM synchromesh) $4.99/qt at Autozone. Smoother shifts.
I've never been able to find that at any Autozone locally.
</TD></TR></TABLE>I've never been able to find that at any Autozone locally.
Synchromesh Friction Modefied, either the GM or Penzoil version....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscrx »</TD></TR><TR><TD CLASS="quote">what kind should i use if my 2nd and third grinds? anything to help it out?</TD></TR></TABLE>
Synchromesh is good stuff. It's been used by many H-T members with good results. They say it eliminated their grinds completely after a few miles. I've noticed that only certain Autozones carry the Penzoil Synchromesh so you may have to look around.
Synchromesh is good stuff. It's been used by many H-T members with good results. They say it eliminated their grinds completely after a few miles. I've noticed that only certain Autozones carry the Penzoil Synchromesh so you may have to look around. </TD></TR></TABLE>
I sold my friend my old Y1 LSD B16 tranny, it grinded in 3rd pretty bad, he used the GM syncromesh and after about a week maybe less, the grinding went away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Yup, after about 50 miles it starts working and after several hundred it's like
</TD></TR></TABLE>Yup, after about 50 miles it starts working and after several hundred it's like
I use syncomesh in my EK....it took a couple hundred miles but my 2nd to third grind disappeared..and the rest of the gears shift much better. That stuff is worth its weight in gold almost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">synchromesh if it doesn't grind.
friction modified if it does. The stuff is simply the best.</TD></TR></TABLE>
Agreed. What is the difference between Synchromesh and the friction modified stuff... I'm running the friction modified stuff.
if you track the crap out of your car (road course/hpde/honda challange etc...) use Motul Gear 300, it's not cheep but the Type-R guys use it all the time in there trannys. For daily driving and occasonial autoxing use eather Honda MTF or Syncomesh. I personally use syncomesh but when i finsh building my new tranny (ZC 1-4, Si 5th and final drive, OBX LSD, Gear Speed carbon syncros) i'll use the Motul for some extra protection and to help out the LSD
1JDMDOMINICAN
Sep 23, 2005 12:38 PM
mika
19
Oct 4, 2004 12:45 PM
integraboi1010
May 21, 2004 09:50 AM
