lower compression
Old Dec 17, 2004 | 02:42 AM
- Sim -'s Avatar
Default lower compression
hey
i want to lower my compression for about 1,0 or so.
in my eu dm stocjk b18c6 engine there is 11.1:1 cr but with my supercharger i want a bit fewer cr.
when i use a cometic head gasket will i have to readjust cam timing then?
Old Dec 17, 2004 | 03:34 AM
Pondus's Avatar
Default Re: lower compression (- Sim -)
If you are getting a thicker headgasket that lowers your CR a whole point then yes i would get a set of adjustable cam gears to readjust cam timing.
Old Dec 17, 2004 | 05:37 AM
- Sim -'s Avatar
Default Re: lower compression (Pondus)
okay thanks.
it just lowers 0,4 points.
thinking that will be okay then.
Old Dec 17, 2004 | 07:33 AM
IN VTEC's Avatar
Are you planning on using aftermarket forged pistons?
I think you should avoid using the head gasket, keep as much quench as possible, and take the chamber volume out of the dome of the piston instead.
Old Dec 17, 2004 | 11:54 AM
BoostR41's Avatar
Default Re: lower compression (IN VTEC)
inline pro has a head gasket that lowers CR 1 full point
Old Dec 17, 2004 | 08:16 PM
Azcheron's Avatar
Default Re: lower compression (BoostR41)
believe it or not
lowering the CR for the supercharger is not what you want to do
if you build up the car right, you dont need to lower the CR
lowering CR with a supercharger like the jackson, doesnt react the same way as lowering the CR with a turbo kit
do more research, i dont know how to explain it well enough to prove my point without getting flamed
NCcwITR
Mar 19, 2004 01:16 PM
McFly
Mar 29, 2003 12:38 PM
NightHawkC5
Feb 20, 2003 08:01 AM
ijjz
Sep 18, 2002 06:55 PM
