Help i'm getting code 22 and 41! what do i do??
i know they are these 22 VTEC pressure valve, 41 Primary oxygen sensor heater
but my question is what is Primary oxygen sensor heater?????
and i have a d16z6 block and i think harness but i have a d15b7 head so i dont have vtec so how do i fix code 22???
well if you don't have vtec then the code 22 will always stay on unless you activate vtec. as for 41 you can check if you can fix the problem if it is just a wire that has been cut other than that i think that the only way to fix that is to get a new o2 sensor
Jdmkids Manny
17
May 12, 2016 02:18 PM
daredeezy619
12
Mar 6, 2008 05:41 AM
