Skunk 2 intake manifold
I have a 99 civic si. I want to put a skunk 2 manifold on. Am i going to see good gains? Is there anybody that is not happy with there's? If so what is better? Also would you install a new trottle body with the manifold? And what kind?
Thanks Dave
Thanks Dave
It'll pull a bit harder but not gains like on the GSR motor. The Skunk2 manifold is basically a Type-R manifold which has shorter runners than the B16 manifold, correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">Nooooooooo!!
The B16 stock intake is better than a Type-R, and the Skunk is a type-R copy.</TD></TR></TABLE>
Si manifold is better than a ITR manifold?
i guess i have never seen flow charts for comparison but seeing as how ITR has more power than Si i'd assume it to be better flowing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD »</TD></TR><TR><TD CLASS="quote">
i guess i have never seen flow charts for comparison but seeing as how ITR has more power than Si i'd assume it to be better flowing... </TD></TR></TABLE>
ITR manifold owns the B16 manifold...you have to port the B16 manifold a lot for it to even compare with the ITR manifold. Also the runners are a bit shorter for quicker air induction and better top end pull.
i guess i have never seen flow charts for comparison but seeing as how ITR has more power than Si i'd assume it to be better flowing... </TD></TR></TABLE>ITR manifold owns the B16 manifold...you have to port the B16 manifold a lot for it to even compare with the ITR manifold. Also the runners are a bit shorter for quicker air induction and better top end pull.
I put a Skunk2 IM on my 99 Si felt good up top, but might of lost some mid-range. I also upgraded TB to a Spoon TB. Picked them both up for pretty cheap($450 for both) so it was worth it. Pain in the *** to install
i have a 95' civic Ex with dc sports exhaust... i want to put skunk 2, but im not sure if i will get the sound that i am looking for, i want to have a deep bassy sound...
B18C-YA!
31
Apr 17, 2006 07:47 PM
