Adjusting ignition timing - not the normal question
Old Dec 16, 2004 | 06:16 PM
Patch's Avatar
Default Adjusting ignition timing - not the normal question
I have a 91 Civic STD that has a D16Z6 swap. I converted the original wiring harness to MPFI, then used a boomslang OBD-0 to OBD-1 conversion harness with a stock P28.
I know you need to jump the service connector to adjust the ignition timing, but should I jump the connector thats part of the boomslang harness used to check codes, or should I jump the connector under the passenger dash (the stock connector). Thanks.
ScottF
Aug 5, 2013 08:58 AM
bigchris2000
May 9, 2010 11:19 AM
crxfreak88
Nov 9, 2009 12:26 AM
Crimson_Tide
Aug 30, 2005 08:56 PM
spooned out
Aug 12, 2003 03:37 PM
