I've come to the conclusion that I'm F*cked
Old Dec 16, 2004 | 05:34 PM
JRciv's Avatar
Default I've come to the conclusion that I'm F*cked
I'm pretty sure I have the wrong supercharger. That's what I get for using ebay.
When I try to drop the charger onto the IM studs, it doesn't fit. The stud configuration is the same, but the nose bolt hits my shock tower (barely) which prevents the charger from going all the way onto the studs. Also, my throttle body location has moved about 8" so that my AEM intake won't fit onto it.
It's obviously a civic charger, but I don't think it's for my year. I can probably hammer the shock tower for clearance, but I definitely will need a new intake.
Any input/advice?
Old Dec 16, 2004 | 05:49 PM
StolenTeg's Avatar
Default Re: I've come to the conclusion that I'm F*cked (JRciv)
You need a short ram intake, jsut use a 3 inch pipe and slap a filter on it. Short ram is better for supercharger so it cool.
Old Dec 16, 2004 | 05:59 PM
JRciv's Avatar
Default Re: I've come to the conclusion that I'm F*cked (StolenTeg)
Is that normal? I was told that the TB should remain in the stock location. It sucks because I put the stupid intake on about a month ago and now it doesn't fit.
Old Dec 16, 2004 | 06:25 PM
donkiman's Avatar
hey man screw the "cold air intake" all it is is rerouting your air filter lol it doesnt do much. the charger is whats inportant. reroute the filter to wherever it will fit with the supercharger on it
Old Dec 16, 2004 | 06:52 PM
Turbo Dan's Avatar
Default Re: I've come to the conclusion that I'm F*cked (donkiman)
that cold air intake is useless with a supercharger because as soon as the air enters that supercharger no matter what temp it comes in as its gonna raise it to about a billion degrees.
im not sure which charger you have, but if it supports an intercooler than i would recommend that.
might as well use a short ram intake, you now have an easy bake oven attached to your engine
Old Dec 16, 2004 | 11:12 PM
JRciv's Avatar
Default Re: I've come to the conclusion that I'm F*cked (Turbo Dan)
Well aside from the intake, what's with the nose bolt hitting my shock tower? Can anyone with a SOHC JRSC tell me how much clearance they have between the blower pulley and shock tower?
I need your help again Sonny
Old Dec 18, 2004 | 02:49 PM
JRciv's Avatar
Bump ---- is it common to have to hammer out the firewall?
Old Dec 18, 2004 | 02:56 PM
Honda_RN's Avatar
some models you actually do have to do some hammering in order to make the clearance you need.. just make sure you have the instructions from JR and make sure its the right model for your car..
Old Dec 18, 2004 | 03:58 PM
JRciv's Avatar
Default Re: I've come to the conclusion that I'm F*cked (Ringbearer020)
Well how do I know it's the right model?
Old Dec 18, 2004 | 04:03 PM
JRciv's Avatar
Here is a pic - the nose bolt hits the shock tower and so will the pulley. I can't hammer out clearance because the other side of the trouble spot is where my upper control arm is mounted.
Old Dec 18, 2004 | 04:04 PM
ImportHatch's Avatar
It should be pretty obvious if its going to fit or not. Try going outside and messing with it.
Yager-
Old Dec 18, 2004 | 05:48 PM
Muckman's Avatar
Moderator in Chief
Maybe you could have someone make a spacer to sit between the blower and the IM. But it would probably cost you more than it would to just sell it and get the right part.
Type-Spaz
11
May 3, 2012 06:20 PM
mitcho
13
Jul 12, 2007 05:39 PM
sickofitall1113
Jun 1, 2005 10:57 AM
escape2me
May 16, 2004 04:41 AM
non vtec
Oct 14, 2002 09:01 PM
