oil leaking from head gasket on b18c1 swap???
I currently have a b18c1 in my 93' honda delsol.....we finished the swap about 3 months ago and everything runs great. The motor had been rebuilt before I bought it...new head gasket, new gaskets all the way around, new water pump, etc. Only problem is it leaks ONLY oil out of the head gasket?????? I'm not sure what to do....anyone have any suggestions or experience with this...please help out....thanx in advance
Are you sure that it is leaking from the head gasket? It may be leaking from the black rubber cam seal next to the distributor. This is fairly common and it will give the appearance that it is leaking from the head gasket area. The rubber cam seal gets hard over time and it begins to leak. I actually have to replace my cam seal, but I will probably wait until spring time when it warms up.
unfortunately its leaking mainly on the side opposite from the tranny (the right side if your looking at it from the front of the car).....so its not near the distributer or vtec sol.
-jared
-jared
its def. coming from the head gasket.... the motor is pretty clean, so you can see where the oil is leaking out of.....I'll see if i can get a picture sometime...
93civic_b18b1
Jan 4, 2002 02:43 PM
93civic_b18b1
Jan 4, 2002 09:37 AM
