Maintinance intervals?
Old Dec 16, 2004 | 10:21 AM
silentblackhat's Avatar
Default Maintinance intervals?
I have a 1999 civic ex 4dr. I bought it with 86K miles oni t. I wasnt sure at all what all has been done with it so i decided to change out the radiator fluid, brake plus, power steering fluid and the oil so i know everything is brand new with honda OEM fluids(except the oil, i used moble one full synthetic, im trying to figure out how to change out the clutch fluid right now tho). What i am wondering is what are the intervals taht i should change those fluids again? I have all honda oem fluid from the dealer in the car. any info would be helpful.
Old Dec 16, 2004 | 10:57 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Maintinance intervals? (silentblackhat)
Read your owners manual, it has all the information you are looking for and that's what it's there for.
Old Dec 16, 2004 | 11:12 AM
Deemeetree's Avatar
Electrician
Engine oil - 3,000
Spark Plugs - 5,000-7,000
Ignition Wires - 25,000
Fuel Filter - 20,000
Transmission Fluid - 10,000
Radiator Fluid - 20,000
Thermostat - 20,000
Water Pump - 90,000
Timing Belt - 90,000
This is a bit on the **** side. But, better safe than sorry.
Old Dec 16, 2004 | 11:39 AM
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">
really every 10K miles? i read somewhere it should be changed around 90K miles. im just findingeverything out so i can keep my car running relaly well because im keeping it till it craps out so i want to take good care of it. i just changed my transmission fluid around 1500 miles ago
Old Dec 16, 2004 | 11:44 AM
EX-T's Avatar
Default Re: (silentblackhat)
30k would be the best interval on you tranny fuild. Is it a manual or automatic?
Old Dec 16, 2004 | 11:54 AM
B2FiNiTY's Avatar
Default Re: (DSeriesBKilla)
Around 15k or 30k is fine depending on how you drive.
Old Dec 16, 2004 | 12:08 PM
flood's Avatar
Default Re: (B2FiNiTY)
Engine oil - 3,000
Thermostat - 20,000
Water Pump - 90,000
LOL, ****? yes.
Sparkplug replacement in the owners manual is like over 30,000 miles. Not to mention that plug wire sets are like $70, I would let them go to about 100k.
Modified by flood at 1:59 PM 12/16/2004
Old Dec 16, 2004 | 02:24 PM
Deemeetree's Avatar
Electrician
Manual states very high mile intervals. Is it safe? Maybe. Is it good to change it sooner? Yes.
It all depends on the your driving and driving conditions. For the most part, most of us don't baby their cars. So, cut down the mileage intervals.
Old Dec 16, 2004 | 02:44 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Manual states very high mile intervals. Is it safe? Maybe. Is it good to change it sooner? Yes.
It all depends on the your driving and driving conditions. For the most part, most of us don't baby their cars. So, cut down the mileage intervals.</TD></TR></TABLE>
The manual states high and low (severe and regular conditions) mileage intervals. Is it safe? certainly...is it adequate? totally...it's a well known fact that owners manual maintenance intervals ARE conservative. Is it good to change it sooner? only if you consider doing things overkill is good and like throwing money away.
No we don't baby our cars but following the severe maintenance schedule is more than adequate for the cars needs.
Old Dec 16, 2004 | 02:57 PM
Deemeetree's Avatar
Electrician
Most parts are cheap anyways. Practically everything is $2-$20, minus wires.
Old Dec 16, 2004 | 03:37 PM
klungemonger's Avatar
I flog my car without mercy, and still only change oil at 5K. Could be running smoother, but no problems to speak of. If you drive like a normal person your oil will probably still be brown if you change it at 3K. A waste of natural resources. Especially if you use synthetics, change the first batch early but the rest you can go longer on.
Platinum spark plugs, which many manufacturers use, have a change interval of 100K miles.
A fuel filter change would be a good idea with that many miles on it. I changed mine around the same mileage you have, it definitely needed it.
DennisWaller
Feb 29, 2016 02:10 PM
Dennis T
Transmission & Drivetrain
Jul 10, 2011 10:41 AM
morris029
Sep 28, 2010 04:15 PM
Jordanasm
Honda Civic (2006 - 2015)
Oct 29, 2009 03:34 PM
tom48
Jul 14, 2008 08:30 PM
