Old Apr 1, 2015, 01:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
power steering flush
Old Dec 16, 2004 | 09:55 AM
arsenal22046's Avatar
Default power steering flush
Hey, my Honda dealer wants $120 for a power steering flush. I have no plans on doing this myself. Should I have them do it, or can I get it done cheaper by someone else? Thanks
Old Dec 16, 2004 | 10:24 AM
Filthy Focker!'s Avatar
Default Re: power steering flush (arsenal22046)
Do it yourself
Disconnect return line to the reservoir and attach a hose to it to direct the old fluid in a canister. Empty the reservoir as much as possible and fill with new fluid. Then have someone start the car and let the old fluid run out until you see clear fluid.
Now, since the reservoir is quite small, it will not take long at all for it to empty itself. Be prepared to *** some if need be.
When it is done. Reconnect line and top off..
fs
Old Dec 16, 2004 | 12:41 PM
Beach Accord's Avatar
you are going to have to do this about 10 times to get results. The dirty fluid is in more than just the reservior....i think there is about 64oz. in the system. I would buy about 10 bottles of Honda PS Fluid to use.
thats what i did with mine.
Old Dec 16, 2004 | 01:35 PM
Turbowa's Avatar
Default Re: (Beach Accord)
WHy are you flushing it in the first place? there really is no need unless you just replaced the rack and/or pump. The power steering fluid is not like all the other fluids it doesn't matter if its dirty or not to work coorectly. That is why its not listed as part of any service in the mait. manual.
Old Dec 16, 2004 | 02:20 PM
there is nothing wrong with it.
the conditioning agents in the fluid break down over time and putting fresh fluid in will make sure all of your seals are properly conditioned.
Old Dec 16, 2004 | 03:42 PM
sj993's Avatar
I beg to differ. Mine p/s went out and I had never changed out the fluid which was very dirty. Whether that had anything to do with it or not I can't say, but I think it's a good idea to change it out at least once a year.
Old Dec 16, 2004 | 06:13 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: (sj993)
Wow 120 dollars.
What seals are we talking about?
Old Dec 16, 2004 | 06:16 PM
Default Re: (-Bionic-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">Wow 120 dollars.
What seals are we talking about?</TD></TR></TABLE>
well, for 120 dollars it's not worth it.
But if you do it yourself it wont cost more than 12-15 dollars.
the seals that are in the p.s. rack.....you know, the ones that keep the hydraulic fluid in its place.
Old Dec 16, 2004 | 06:24 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">
the seals that are in the p.s. rack.....you know, the ones that keep the hydraulic fluid in its place.</TD></TR></TABLE>
True. If we are talking about using ten bottles of p.s fluid wouldn't that be more than 12-15 dollars? I'm just curious. Regardless, I have to flush the system if I decide to install the p/s pump one day. Thanks for the info.
Old Dec 16, 2004 | 06:32 PM
well, i get a bottle of fluid for about 1.70 at my honda dealership....
Old Dec 16, 2004 | 08:04 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">well, i get a bottle of fluid for about 1.70 at my honda dealership....</TD></TR></TABLE>
Ooh ok. I thought it would cost more because everything at the dealer is.
Old Dec 16, 2004 | 09:30 PM
Schmitey's Avatar
That's crap, I guarantee the guy is just gonna smoke a cigarette and milk it out to be a one hour job. $120, what is the world coming to?!?
There's really no need that I see to flush the system unless you got boo koo rust in it or something. What am I saying, be a man and get a work-out...while saving horsepower at the same time. You don't need no stinkin' power steering!!!
But seriously, does it matter what type of power steering fluid you use? In my old 90 Eclipse the manual said to use ATF fluid (damn, I can proudly say I don't have any of that crap anymore, manuals rule the world!!!).
Old Dec 17, 2004 | 08:26 AM
yes, honda power steering racks are very sensitive and you should only use honda PS fluid in them.
told this by many master mechanics and also my 3 instructors at school.
Old Dec 17, 2004 | 10:49 AM
Elvis1977's Avatar
yeh, honda fluid is the best. But, I believe that fushing your entire system is not necessary. What i do is periodically siphen out the resivior and add new fluid. Yes, the fluid gets dark again after you start the motor because it mixes with other existing fluid. But, you have added some fresh fluid. Look at the manual. No book requires mainenance for flushing the power steering UNLESS there is an existing problem.
Old Dec 17, 2004 | 11:05 AM
Blanket Jackson's Avatar
True dat ^^^^, my Honda dealership recommends it every 60K just to be safe on the seals, cuz a PS rack isn't cheap for me or you (me as in parts)
Old Dec 17, 2004 | 02:29 PM
alotawatts's Avatar
Check a Helm manual and Forum search for the procedure. When you drain via the return hose you need the car running and turn the wheels full to the left and right etc.
CivicObligation
Honda CR-V & Element
Apr 3, 2013 05:10 PM
theineffable
Honda Civic (2001 - 2005)
28
Sep 25, 2012 08:30 PM
curtie94
Feb 24, 2012 12:38 PM
old_school_dohcvtec
Jan 18, 2006 03:23 AM
oryanh
Jul 7, 2002 05:25 PM
