Opening dual runner earlier than 5800 ?
Old Dec 16, 2004 | 08:16 AM
X2BOARD's Avatar
Default Opening dual runner earlier than 5800 ?
I have a BIG jump in power at 5858 right now and the tune I'm running had the fueling set for a dual runner mani. But the burst in power is enormous (for n/a) when the runner opens. I tried leaving the runner constantly open, but low end does suffer and the car still has a smack in the *** at 5858 (prolly due to ecu tune).
What I want to do is have the runner come in about 1k rpm sooner than stock. Just wondering if anyone has done this on a modded gsr ? I have larger than stock bore and more compression... so I figure I might be able to utilize the 2ndary earlier than usual.
COmments ?
Old Dec 16, 2004 | 09:25 AM
99-DC2's Avatar
Default Re: Opening dual runner earlier than 5800 ? (X2BOARD)
what cams are you running?
Old Dec 16, 2004 | 09:42 AM
X2BOARD's Avatar
Default Re: Opening dual runner earlier than 5800 ? (DC2-99)
Still on the stock gsr cams. Most of the work is on the bottom end.
Old Dec 16, 2004 | 10:11 AM
CHEETAH's Avatar
I can modify on all my programs, if you can;t find anyone and need an eprom from me PM me or email gbrtuning@aol.com
Greg
Old Dec 16, 2004 | 10:15 AM
X2BOARD's Avatar
Default Re: Opening dual runner earlier than 5800 ? (CHEETAH)
Thanks Cheetah, but I have a chip, I know it can be changed for the dual runner, but what I wanna know is will I be able to make power and have more power under the curve if I lower the rpm req'd to open the 2ndary ?
BTW, I really like the low end the dual runner manifold gives, which is why I haven't contemplated switching or upgrading just yet. (stock header and manifold catches ALOT of people off guard...lol)
Old Dec 16, 2004 | 11:14 AM
99-DC2's Avatar
in my experience changing the opening of the dual runners on stock GSR cams gives no net effect... more likely it is a timing or fuel map issue... my tuner tried it on my Hondata S100 and whenever he changes the opening of the dual runners and adjusts timing and fuel for it adequately it yields almost the same power curve as when he leaves it at stock activations (4400 VTEC and 5600 short runners, i think)... i assume it would behave the same way with a higher compression motor only the curve will be higher (HP & Torque)...
Old Dec 16, 2004 | 11:45 AM
X2BOARD's Avatar
Well... I'm hoping the larger displacement and compression will give me a couple horses in that area. I mean the dual runner coming in is like a kick in the *** right now... not smooth like a stock setup at all.
Old Dec 16, 2004 | 11:47 AM
99-DC2's Avatar
you need to get it tuned...
Old Dec 16, 2004 | 11:54 AM
X2BOARD's Avatar
Of course... saving for the dyno as we speak.
Old Dec 16, 2004 | 11:56 AM
hayabusa160's Avatar
when my car was tuned. the higher up we moved the secondaries the more power it made strange right lol. i have a ported gsr manifold and skunk2 stage2 cams.
at one point he set the secondaries the same at vtec. later moved it all the way to 7100 picked up a good bit at the midrange top end didnt suffer at all from it.
driving around when they open up the power surge is nuts. i feel the secondaries kick in its way louder then vtec and ur head just gets thrown back.
Old Dec 16, 2004 | 11:59 AM
X2BOARD's Avatar
Default Re: Opening dual runner earlier than 5800 ? (hayabusa160)
With the stock cams, that's pretty much what it feels like... you get pinned in the seat somewhat. Vtec engagement at 4800 is quite tame.
Old Dec 16, 2004 | 03:15 PM
Mike@K-Tuned's Avatar
I had a similar issue with my gsr motor. The power jump when the butterflies opened was very obvious. It got worse when I installed ctr cams. I removed the butterfly assembly completely from the manifold and had it ported. I also switched to a chipped p28 ecu and tuned it properly for fuel and timing. After the ecu was tuned my engine pulled even harder through the whole power band. The dyno will help you tons. Good luck
Old Dec 17, 2004 | 04:47 AM
X2BOARD's Avatar
Default Re: Opening dual runner earlier than 5800 ? (EGgsrAM)
^^ good to hear, since I will prolly upgrade to ctr cams as well... damn aftermarkets are mega expensive down here. What kinda #'s did you dyno w/ those cams ?
Old Dec 17, 2004 | 05:28 AM
My JDM GSR motor w/stock block (10.6 comp), chipped p28 ecu, VAFC, ctr cams, type r tranny, ported manifold, and I/H/E put out 178 whp and 127 tq. It took about an hour to tune the engine on the dyno. A/F ratio running at about 13.2. I don't have cam gears yet (but soon). Not bad power at all, but I still want more. What kinda numbers are you expecting?
Old Dec 17, 2004 | 07:02 AM
X2BOARD's Avatar
I might be a lil optimistic, but I'm expecting about 170/180-ish on the gsr cams and 11.6:1 CR, purely based on past races. But with my clutch slipping the way it is...I won't be seeing the dyno for a little while longer.
Old Dec 17, 2004 | 12:49 PM
You have 11.6 comp (did you change pistons) or do you mean 10.6 which is stock for JDM GSR?
Old Dec 20, 2004 | 05:23 AM
X2BOARD's Avatar
I had the car in the states for a year or so... so I have a usdm engine.... and I rebuilt the block.
Integrity_On_Wheels
Sep 10, 2006 08:45 AM
bOOsTiNSoHcVtEc
Jun 29, 2005 05:23 PM
TurboB18C1
Jul 18, 2004 05:44 PM
Thurman Merman
Jul 1, 2004 08:47 PM
civicguy
Jan 13, 2003 01:58 PM
