can you go back to regular motor oil if you use synthetic oil ?
Old Dec 15, 2004 | 10:49 PM
Jdmcivic98's Avatar
Default can you go back to regular motor oil if you use synthetic oil ?
i heard that if you go synthetic motor oil you can go back to regular motor oil is it true ? and which one is better ?
Old Dec 15, 2004 | 11:48 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: can you go back to regular motor oil if you use synthetic oil ? (Jdmcivic98)
break a motor in with conventional oil. once you start using synthetic, stay away from convetional. always use synthetic from that point on, until your engine dies.
synthetic oil, in nearly every aspect, is much better than conventional. why? because synthetic was designed in a lab to be better than conventional. the only bad thing about it is the cost. it's about twice as much as regular oil.
Modified by MugenDude at 4:05 AM 12/16/2004
Old Dec 16, 2004 | 03:49 AM
civic-4-ges's Avatar
Default Re: can you go back to regular motor oil if you use synthetic oil ? (MugenDude)
Synthetic is better than conventional...its more "slippery" so to say
You can go back to convetional oil after using synthetic, can't think of a reason why you couldn't
Old Dec 16, 2004 | 04:45 AM
snatch's Avatar
Default Re: can you go back to regular motor oil if you use synthetic oil ? (civic-4-ges)
I've always heard/been told/read that switching back and forth from conventional to synthetic or vice versa is not a good idea. Once you select one, (except for break-in period with conventional, that's ok), that you should stick with it.
Old Dec 16, 2004 | 05:49 AM
JimBlake's Avatar
Default Re: can you go back to regular motor oil if you use synthetic oil ? (******)
I've always heard it's not good to keep switching brands around, doesn't matter if it's synth or not. The additives don't always play nice with each other, even tho it's only a little bit that doesn't drain out. So try to pick a brand & stay with it.
Switching from one brand to another, or switching from synth to petro, is OK as long as you're not constantly going back & forth.
Old Dec 16, 2004 | 11:14 AM
turboxsi's Avatar
The whole myth behind this, is how your rubber gaskets in the engine are effected from switching between the two types of oils.
turbochargeb18c
Jun 18, 2005 04:20 PM
stock97
Apr 28, 2003 08:22 AM
blackhatch13
Mar 28, 2003 08:01 PM
crxhybrid1320
Feb 7, 2003 05:22 PM
NeoGSR
Nov 17, 2002 01:38 AM
