Mugen ecu install help
Old Dec 15, 2004 | 05:37 PM
KS-R's Avatar
Default Mugen ecu install help
Is there a trick to installing the Mugen ecu? Is there some special procedure or trick? I installed the Mugen 9000rev limit ecu into a Type S and we weren't able to get the car running.. Well.. it would only start up if your foot was pegged on the gas... it would stall as soon as you try to idle the car.. Any help would be greatly appreciated.
Old Dec 15, 2004 | 06:52 PM
dacaveman's Avatar
Yes there is a trick to it. I don't remember it though. I believe you had to ground the ecu and possibly cut a wire.
Old Dec 15, 2004 | 07:22 PM
KS-R's Avatar
Default Re: (dacaveman)
OK. at least that backs up my suspicion. Now... anyone actually know the solution? TIA.
Old Dec 15, 2004 | 09:35 PM
DC5ITR329's Avatar
Default Re: (KS-R)
you have to hard wire the fuel pump or somthing.
Old Dec 15, 2004 | 10:50 PM
mister x's Avatar
Default Re: Mugen ECU
From King Motorsports:
"Installation on the US Market RSX-S (2002-2004) requires the following modification. Behind the glove box there is a fuel pump relay. The Green/White wire used by the relay needs to be spliced and a wire run to ground. "
Old Dec 16, 2004 | 07:12 PM
MooFX's Avatar
Default Re: Mugen ECU (mister x)
You will have to ground out the fuel pump relay wire, as Kingmotorsports stated.
We have to do it everytime we send out a customer's ECU out to hondata for reflash, when we give them our loaner DC5-R ecu.
drivingshadow
May 16, 2015 07:25 PM
JT2
Honda Civic (2001 - 2005)
Jun 23, 2009 06:37 PM
tegdude227
Jan 31, 2009 03:59 PM
clinicmotorsports
Feb 15, 2007 08:42 AM
SuicideSlide
Feb 17, 2005 03:09 PM
