engine vibrates when I turn it on and wants to die
Old Dec 15, 2004 | 03:04 PM
goldenboi's Avatar
Default engine vibrates when I turn it on and wants to die
I got a 00 civic d16vtec. when I start it up it vibrates a lot more than usual and acts like its going to stall out on me. after it warms up it chills out a lil but still vibrates more than usual. the only mod is an intake and no the mounts arent broke. does anyone have any ideas? i searched and got "sorry 0 results found"
Old Dec 15, 2004 | 03:10 PM
Koyoloeor's Avatar
Default Re: engine vibrates when I turn it on and wants to die (goldenboi)
check ur injectors.....mine did the same and i wiggled them this morning and noticed one was broke....i changed it and it no longer vibrates or studders when driving
Old Dec 15, 2004 | 03:14 PM
goldenboi's Avatar
Default Re: engine vibrates when I turn it on and wants to die (CfS2000)
if they were dirty would it act the same?
Old Dec 15, 2004 | 03:31 PM
goldenboi's Avatar
also if the valves arent adjusted right would it cause it to vibrate all crazy?
Old Dec 15, 2004 | 03:34 PM
Deemeetree's Avatar
Electrician
It could be a number of things. You definitely need to start at the bottom and most obvious and cheap, then work your way up.
Check:
Spark Plugs.
Ignition Wires.
Coil.
Injectors.
Any harness unplugged.
Any CEL that came up.
If you did a valve adjustment, did you do it right? Did you use the OEM-spec lash clearances for intake and exhaust sides?
have you used any additive to your fuel system?
Old Dec 15, 2004 | 03:40 PM
goldenboi's Avatar
Default Re: (Dimi)
no additives and I had a mechanic do the valves. Ill check around real good in the engine bay. cel?
Old Dec 15, 2004 | 05:07 PM
goldenboi's Avatar
Default Re: (goldenboi)
ttt
Old Dec 15, 2004 | 05:09 PM
jlacoy82's Avatar
71.192.16.183
Is there oil in the engine?
Old Dec 15, 2004 | 08:16 PM
goldenboi's Avatar
Default Re: (jlacoy82)
all fluids are go
Old Dec 17, 2004 | 04:51 AM
goldenboi's Avatar
help me this is annoying
Old Dec 17, 2004 | 06:20 AM
EKhothatch's Avatar
Adjust the idle.
Old Dec 17, 2004 | 11:52 AM
boricuatuning's Avatar
make sure the engine is in correct timing and make sure your dist. is firing in the correct order. Get a fuel pressure gauge and make sure your not lossing pressure after the car starts. Good luck
Old Dec 17, 2004 | 12:27 PM
The Internet Tough Guy's Avatar
Default Re: engine vibrates when I turn it on and wants to die (boricuatuning)
fork over the $8 for some new spark plugs.
Old Dec 17, 2004 | 05:30 PM
texasnick's Avatar
I would say do a compression test and make sure your not losing pressure in the cylinders.
if not, it is probably missing cylinders as it fires. Spark plugs, distributor, all of that ****.
Good luck
scotty.b16a1
Jan 2, 2013 04:54 AM
sethmoman
12
Dec 28, 2011 10:00 PM
civic46
11
Sep 12, 2010 05:25 PM
dc2teg2006
Aug 25, 2008 08:20 AM
DaBzzMN
Mar 6, 2006 05:03 PM
