using vafc as monitor ONLY... which wires do I NOT connect?
Old Dec 15, 2004 | 02:07 PM
Black R's Avatar
25 Year Member
Default using vafc as monitor ONLY... which wires do I NOT connect?
Possible, or waste of time?
Old Dec 15, 2004 | 02:20 PM
uNF$@#!'s Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">Possible, or waste of time? </TD></TR></TABLE>
depends what you want to monitor.
just install it properly, and dont change any settings. (initialize), and thats it.
I'm using a vafc right now as a monitor only.
Old Dec 15, 2004 | 02:48 PM
Bbasso's Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (255.255.255.255)
Using it as a monitor too
Old Dec 15, 2004 | 02:53 PM
Nishant's Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Using it as a monitor too </TD></TR></TABLE>
i don't remember seeing it in your car *thinks*
Old Dec 15, 2004 | 02:55 PM
Bbasso's Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (Nishant)
hehe I hide it behind the crap in the cup holders
Old Dec 15, 2004 | 03:05 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">hehe I hide it behind the crap in the cup holders </TD></TR></TABLE>
good spot
i wonder where i should put mine
Modified by Nishant at 7:58 PM 12/15/2004
Old Dec 15, 2004 | 03:49 PM
HondaRcB's Avatar
I plan on doing this too once I get my Hondata, it just looks so pretty.
Old Dec 16, 2004 | 11:47 AM
Nytemare's Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (HondaRcB)
If its just a monitor why don't you just get an Apex-i rev-speed meter? It's alot cheaper and thats pretty much what its meant for anyways.
Old Dec 16, 2004 | 11:52 AM
B2FiNiTY's Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (Nytemare)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nytemare &raquo;</TD></TR><TR><TD CLASS="quote">If its just a monitor why don't you just get an Apex-i rev-speed meter? It's alot cheaper and thats pretty much what its meant for anyways.</TD></TR></TABLE>
VAFC monitors different items.
Old Dec 16, 2004 | 12:04 PM
Nytemare's Avatar
Default Re: using vafc as monitor ONLY... which wires do I NOT connect? (B2FiNiTY)
Yeah the VAFC shows different items but in order to read those signals you have to connect those wires anyways. So then there would be no point in asking the question. right? like how can it monitor those items if the wires for the signal arent even connected.
Old Dec 16, 2004 | 12:13 PM
esponet's Avatar
you can connect all the wires properlly and then just don't mess with it, do set the vtec switch over to whatever the ecu setting are.
you practically have to connect every wire anyways. to use all of its monitoring otions
Old Dec 16, 2004 | 12:16 PM
cheezthis's Avatar
Not quiite...do not connect the vtec in and out wires. Unlike, say, hondata, where you can set the vtec crossover by rpm as well as throttle, vafc is on or off based on rpm only.
Everything else can be connected and not altered. Keep the vtec controls on the vafc for something like a...umm...shift light I guess.
Old Dec 16, 2004 | 12:23 PM
esponet's Avatar
if you connect the v tec in and out wires, you can also monitor when your vtec is on or off.
Old Dec 16, 2004 | 01:14 PM
Reid's Avatar
Global Moderator
Default Re: (esponet)
Connect everything and do not change any settings.
Old Dec 16, 2004 | 01:39 PM
RTW DC2R's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Connect everything and do not change any settings.</TD></TR></TABLE>
I prefer using a 20" flip down monitor to monitor stuff
Old Dec 16, 2004 | 01:47 PM
Reid's Avatar
Global Moderator
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I prefer using a 20" flip down monitor to monitor stuff </TD></TR></TABLE>
Why did you quote me? I don't see any typos or anything.
Old Dec 16, 2004 | 02:37 PM
RTW DC2R's Avatar
"Reid (5:47 PM 12/16/2004):
Post Edit Notification
Your post in thread using vafc as monitor ONLY... which wires do I NOT connect? has been edited."
Ken give me your ECU, focker!
vx_civic
Oct 11, 2005 09:33 AM
shadykit
Mar 4, 2005 10:12 AM
civilEX98
Feb 4, 2005 07:45 AM
Eziekel
Jan 7, 2004 09:44 PM
Scratchin
Oct 6, 2003 10:33 AM
