Skunk2 Manifold THrottle cable question
for the GSR swap into an EG
I am running the Skunk manifold
what throttle cable and bracket are recommended
Im tired of the rigged setup I am running
which is the OEM cable and some metal straps and the b16 bracket
HELP!
I want this to be a cleaner application
HELP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">itr bracket
itr cable</TD></TR></TABLE>
I am using an Ls 94 cable with an Ls bracket. I had to bend the bracket a bit for now. I plan to get an ITR bracket, for better fitment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGgsrAM »</TD></TR><TR><TD CLASS="quote">If you want it to be super clean and oem looking use oem itr bracket and cable, just like gsr dan said.
resurrecting this thread,
for skunk2 on 01 GSR, i just installed the ITR throttle cable and bracket, along w/ ITR butterfly, i initially used the same spring off the GSR TB, but apparently since the spring mounting location is different, the spring tension is all gone so the gas pedal feels really light, then i used my friend's old ITR TB spring, it feels slightly better, but still not as the same tension as original w/ GSR TB, cable, etc, what to do?
hmm interesting
however I have a Holley 68mm Throttle body on it
so I wonder if its going to work the right way
my throttle pedal is pretty tight as it is
sir2k
Oct 29, 2003 11:19 PM
