motor mounts on a del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by losder riper »</TD></TR><TR><TD CLASS="quote"> need to know if eg hatch and del sol are the same mounts for the swap</TD></TR></TABLE>
What do you mean? Are you asking if you could use the eg and delsol mounts? Or are you asking if they are the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by losder riper »</TD></TR><TR><TD CLASS="quote">im puting a b16a2 in my del sol and need to know if eg hatch and del sol are the same mounts for the swap</TD></TR></TABLE>
yes, ac bracket/mount is different though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by losder riper »</TD></TR><TR><TD CLASS="quote">AC MOUNT OF A GSR WONT WORK?</TD></TR></TABLE>
No it won't, you need one out of a dohc delso.
I can tell you that the Del sol rear mount is not the same as later Civic D series mounts. the drivers side mount is different as well. I just dropped a 97 EX motor into my 93 Del Sol Si last week and the mounts were certainly not the same. The rear mount was shorter by a good half inch and will not bolt up.
