eg platform =Del Sol Platform?
Old 01-13-2010, 08:22 AM
kct01's Avatar
Default eg platform =Del Sol Platform?
Okay, Noob question. Can I swap over my complete H swap in a EG into the del sol without buying anything new? Did honda use the same frame platform? I know its a branch of the civic replacing basically the crx. Will it run better in the sol or the same as in the EG.
Old 01-13-2010, 08:28 AM
shoklid's Avatar
Default Re: eg platform =Del Sol Platform?
the motor will run the same no matter what car its in. umm u would need new hasport mounts only one that can be universal is driver side. and no the 2 cars are diff in many ways. and delsols are heavier than eg's if its a hatch.
Old 01-13-2010, 08:50 AM
Wakes4Fun's Avatar
If you already have the H-series in your EG then no you don't need anything else to get it in the Del Sol. And its a H-series its going to pull pretty hard in any honda you put it in. lol
Old 01-13-2010, 09:10 AM
EFPhilly's Avatar
No you are wrong, you put it in the sol and it instantly increased Horsepower DUH! Put it in the sol, not very many 22es in sol's
Old 01-13-2010, 09:45 AM
bar'dh22's Avatar
i have a h22 sol
Old 01-13-2010, 10:00 AM
EFPhilly's Avatar
Ahhhh that is clean, certified and everything. I was talking about the h22 sol to h22 civic ratio. Very nice swap any pictures.
Old 01-13-2010, 10:53 AM
kct01's Avatar
ahhhhhhh I like I like (badge) and I miss Cali lol. So I wouldn't need anything new to swap it from my EG to the Sol right? Engine bay is the same I suppose. How's the traction on the sol with h22 and it being a t-top. Does it affect anything since it's a t-top? I'm in the high 12's with the hatch so possibly low 13's with the sol/moderate strip to the car and light weight reduction? What are your times at the track "Bar'dH22"? how does the car handle from the civic? Man I'm really considering the swap into the Sol!
Old 01-13-2010, 11:30 AM
itsnotfast's Avatar
I believe you will need different shift linkage.
Old 01-13-2010, 11:55 AM
bar'dh22's Avatar
you wont need anything everything is the same
Old 01-13-2010, 06:36 PM
kct01's Avatar
Still have to mod the transmission side and hook up the cable shift link? What are your times at the track bar'dh22?
Old 01-13-2010, 07:06 PM
bar'dh22's Avatar
its not a track car its a dd im gonna build a h22 turbo
Old 01-13-2010, 07:13 PM
92shade's Avatar
is this a h2b or straight h22 everything because you will still need to convert the shifter to cables if not already done so
Old 01-13-2010, 08:17 PM
jdm.coupe3234's Avatar
everything will switch over fine only thing u will need different i belive is the shift linkage..
Old 01-13-2010, 09:57 PM
bar'dh22's Avatar
dont post if you dont know , you would only need new linkage if it was a h2b but he stated complete h swap so you wont need anything
Old 01-14-2010, 05:56 AM
kct01's Avatar
It's a str8 h swap with cable links and the Sol is a 93 S auto. Does it matter if the Sol's a manual or auto?
Old 01-14-2010, 07:49 AM
shoklid's Avatar
wow so eg motor mounts are the same as a delsol is what everyone is saying. but hows come my eg pass mount dnt work for my sol . hmm
Old 01-19-2010, 03:56 PM
jerryscherry's Avatar
I actually need help on the shifter cables crap, it doesn't seem to be shifting right now.. don't know if the hole is big enough... or is there some modifying that needs to be done?
seems like the cables need more clearance.. any help is greatly aprreciated. using a prelude shift linkage right now.
the transmission end is fine because we can move the **** on tranny to shift gears but.. from the **** -->cable----->shifter doesn't shift
hopefully we can just take the front dash off... and not take the whole motor out
305S0L
09-19-2009 04:35 PM
Han Solo
10
07-19-2005 10:42 AM
Jmorin
20
07-15-2004 07:56 PM
Quick Reply: eg platform =Del Sol Platform?
