Need help installing o2 sim. in obdIIb car
Old Dec 15, 2004 | 08:37 AM
BeerBaron105's Avatar
Default Need help installing o2 sim. in obdIIb car
hey guys, search is down so i need some help
my car is a 99 civic dx with an b16a2, so essentially its a 99 Si (SiR), i have an o2 simulator for my secondary o2, but im not sure which pinouts are for the secondary o2 signal, and i need a power, and ground signal, could u guys help me out??
Thanks!
Old Dec 15, 2004 | 08:56 AM
Spade's Avatar
Default Re: Need help installing o2 sim. in obdIIb car (BeerBaron105)
A8 and A23 are two of the O2 wires.
Old Dec 15, 2004 | 08:59 AM
so those are for the secondary o2 correct? is a8 the heater wire, and a23 the signal wire?
could also tell me a power wire and a ground wire out of those wiring schematics, thanks
Old Dec 15, 2004 | 09:43 AM
menkio's Avatar
Default Re: (BeerBaron105)
bump, and make sure you tell us it worked !
Old Dec 15, 2004 | 09:55 AM
Spade's Avatar
Default Re: (menkio)
Once the search is available again.
Search for FAQ in the Archives, created by Spade
There will be a ECU pinouts thread that has engine bay wiring diagrams.
Old Dec 15, 2004 | 10:13 AM
okay well i installed it, but i still have a check engine light (ecu reset) so im thinking it has something to do with the heater wires not being plugged up to anything, i think im gonna have to wire a resistor in the heater wires
Old Mar 29, 2005 | 08:42 AM
dwnthehatch's Avatar
Did you ever figure it out? I just swapped a 99 b16a2 into a 99 dx hatch and need to wire up the secondary 02 sensor. I'm using the 99 si engine harness. I removed the secondar o2 sensor plug and wires from the DX engine harness. Do the pins go into the same locations in the si ecu plugs?
Dominicandude
Mar 10, 2006 10:16 PM
SkElLyTuRbO
Oct 6, 2005 03:27 PM
vladd
Dec 5, 2003 08:42 PM
RSZero1
May 13, 2003 08:29 AM
H23vtecEG
Apr 4, 2003 08:12 AM
