Loose rotor in distributor
Old Dec 15, 2004 | 07:33 AM
shizam's Avatar
Default Loose rotor in distributor
Does anyone know if your rotor inside your distributor is supposed to wiggle side to side?
The actual shaft it's screwed onto is able to turn a bit back and forth... Is this normal?
2000 Honda Civic DX
Thanks in advance for any help
Old Dec 15, 2004 | 07:39 AM
AutoXer's Avatar
Default Re: Loose rotor in distributor (shizam)
Is the screw in there tight? Is it stripped?
Old Dec 15, 2004 | 07:42 AM
IVI's Avatar
IVI
last time i changed my rotor, it was tight, and the only way i turned it to get to the screw was cranking the motor for a second.
Old Dec 15, 2004 | 07:46 AM
2lua's Avatar
the distributor shaft should have a bit of play. not much
Old Dec 15, 2004 | 07:56 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Loose rotor in distributor (2lua)
If it's more than about 10 degrees of total play, I'd be careful. I had a buddy who's rotor flew off at 7000 rpm and detonated the inside of the dizzy. That's an expensive repair .
Old Dec 15, 2004 | 09:32 AM
shizam's Avatar
Default Re: Loose rotor in distributor (EX_AutoXer)
The screw/spring washer look fine, no stripping detected.
Does anyone have one of those car manuals that will say whether the shaft it connects to is allowed to have ANY free play? I would think that if it is able to move, that would change the spark timing...
Old Dec 15, 2004 | 09:53 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shizam &raquo;</TD></TR><TR><TD CLASS="quote">
Does anyone have one of those car manuals that will say whether the shaft it connects to is allowed to have ANY free play? </TD></TR></TABLE>
So you're talking about the shaft itself, and not the rotor on the shaft? Then yes, the shaft itself will have some play or 'backlash' just as your transmission does.
Old Dec 15, 2004 | 10:17 AM
Unceasing Measure
I just looked through the distributor section of the Helms manual for 15 minutes and couldn't find anything about lash specifics for the dizzy shaft. A little movement is normal. A lot (30+ degrees) would be something to worry about.
Old Dec 15, 2004 | 12:00 PM
shizam's Avatar
Default Re: Loose rotor in distributor (Archidictus)
Ok, thanks for your help everyone on this, just want to make sure nothing is messed up!
mellowman164
Jan 12, 2014 10:59 PM
BIGPAPAWACK
10
Aug 23, 2010 11:51 AM
slowcivic2k
10
Jan 17, 2009 03:35 PM
Rory Breaker
Mar 3, 2003 02:25 PM
