TDC Sensor CEL 8 dizzy is good, what now?
Old Dec 14, 2004 | 07:55 PM
thumbtack's Avatar
Default TDC Sensor CEL 8 dizzy is good, what now?
Ok I checked the distributor (6 month old from distributor king), and it is within spec (447 Ohms), I also checked the wiring from the main harness and it is also good. Maybe bad ecu, but before I shell out $150+ for another one....
Can the timing of the vehicle affect this sensor? Ignition timing is set all the way advanced. I need to get this cleared up before I install my turbo setup... I have all the parts for my setup in my garage waiting to go in. I have messed with this problem for awhile now and nothing I do seems to clear it.
The car runs fine, very healthy, but once you get above 3500rpm, CEL again.
What other things could cause this problem?
Old Dec 14, 2004 | 08:07 PM
mmuller's Avatar
Mad Scientist
Default Re: TDC Sensor CEL 8 dizzy is good, what now? (thumbtack)
try another dizzy to see wha happens
Old Dec 31, 2004 | 07:24 AM
aut0tek's Avatar
Default Re: TDC Sensor CEL 8 dizzy is good, what now? (mmuller)
Any news? I just developed the same problem a couple nights ago hopefully it doesn't come back... it only happened becasue it was the first night after the new build that I got the beat on her... And I got through 3rd and into 4th and it says "BLING code 8, 14 (the plug fell off), 20 (I don't have an ELD) and 22 (long story I just grounded the wire and let it roll.)
Ratliff
AZintegragsrT
Jul 24, 2009 09:03 AM
Eighty-Nyne
Sep 10, 2008 09:37 AM
.Kevin.
Sep 12, 2005 12:51 PM
