Axle Replacement
Old Dec 14, 2004 | 07:29 PM
greenDC2's Avatar
Default Axle Replacement
I replaced my passenger side axle on my Integra GSR, and noticed a slight vibration under acceleration, especially before VTEC hits. Does changing the axles alter any alighnment??? Thanks guys.
Old Dec 14, 2004 | 08:48 PM
quik1's Avatar
Default Re: Axle Replacement (greenDC2)
Are you sure that it is all the way in? If its not it could cause the symtoms you are discribing.
Old Dec 15, 2004 | 06:46 AM
greenDC2's Avatar
Default Re: Axle Replacement (quik1)
Yea its definetly all the way in, by the way it is a remanufactured axle from a local parts place around here.
Old Dec 15, 2004 | 06:53 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Actually mine does the same thing and i just replaced an axle. My alignment is off badly though so im thinking that may be it. its trying to pull the wheels and making it vibrate.
Old Dec 15, 2004 | 07:05 AM
atcrx's Avatar
Default Re: Axle Replacement (JDM_Ej)
If in installing the axle you let the inner joint pull to far out the tripod bearing could fall off and it will cause it to vibrate. Had it happen on a clutch replacement job on a crx.
Pwnmeister
Jun 25, 2013 07:55 AM
B18CivicEH2
Mar 19, 2007 05:13 PM
Reelizmpro
Dec 17, 2004 03:25 PM
philipkrotch
Jan 22, 2003 10:46 AM
