h22 clutch line question???
Old Dec 14, 2004 | 05:02 PM
EGhatch22's Avatar
Default h22 clutch line question???
im trying to hook my clutch line to my transmission but im not quite sure where it goes can some explain where it goes or show me a picture, it would be a big help thanx
Old Dec 14, 2004 | 05:19 PM
mgags7's Avatar
well there its a complicated system on the prelude for the clutch...
you have the good old master cylinder....
then the hard line running across the firewall
mounted on the side frame behind the transmission there is a damper which that hard line goes into and then comes out.....
a couple inches more and the hard line couples with a soft line...
the soft line goes into that "body" on the top of the transmission, then a hard line comes out of that, and runs to the slave cylinder....
its a pain in the ***.....
you might just be better off trying to make an extension for your hard line and run it straight to the slave cylinder....not sure how well it will work but its a thought.....
B18c5__Owns
Mar 25, 2009 12:48 PM
prelude72569858
Sep 14, 2008 08:00 PM
JasonST
Feb 7, 2006 06:05 AM
jdmcivicferio
Feb 19, 2003 04:30 PM
