Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
**S2000** Owners - BuddyClub Dampers!!!
Old Dec 14, 2004 | 03:58 PM
jdmstylesi's Avatar
Default **S2000** Owners - BuddyClub Dampers!!!
RoBear Racing is proud to offer the S2000 community a great deal on Buddy-Club suspension!
Racing Spec Damper" is the perfect complete suspension kit with resemblance of P-1 racing damper's excellent designs while it is de-tuned for street - circuit use. However, the car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests
With an adoption of a "adjustable bracket" the ideal low postion can be achieved without any use of helper spring. One rotation, approximately 2mm, will enable the user to change the length of the damper. Dampers are black plated rather then painted for extra durability.
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissapation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chasis movement. Caster adjusment allows the correction of camber for further tuning ability.
Tremendous enhancement in durablity resulted from a high quality surface processing. Constant testing resulted in a perfect spring rate for each application.
We have several sets in stock.
S200 Buddy-Club Racing Spec Dampers (Complete Set)
PM me for incredible price!
Call us at 909-982-4927 to order.
Supplies wont last long at this price!
Modified by RobearRacing at 6:39 PM 12/15/2004
Old Dec 15, 2004 | 10:31 AM
jdmstylesi's Avatar
Default Re: **S2000** Owners - BuddyClub Dampers!!! (RobearRacing)
bump
Old Dec 15, 2004 | 02:04 PM
jdmstylesi's Avatar
Thanks for the orders, 5 left in the US at this price!
Old Jan 19, 2005 | 01:32 PM
jdmstylesi's Avatar
bump
Old Jan 20, 2005 | 01:38 PM
BRICKHEAD's Avatar
Check PM and please let me know.
Old Jan 21, 2005 | 08:33 AM
jdmstylesi's Avatar
Default Re: **S2000** Owners - BuddyClub Dampers!!! (BRICKHEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRICKHEAD &raquo;</TD></TR><TR><TD CLASS="quote">Check PM and please let me know. </TD></TR></TABLE>
Gotcha back.
I get so many PM;s but no one takes them.
Old Jan 23, 2005 | 10:41 PM
Mr. Lucky's Avatar
price?
Old Jan 24, 2005 | 08:49 AM
jdmstylesi's Avatar
Default Re: **S2000** Owners - BuddyClub Dampers!!! (bs-inc.s2k)
PM sent
Old Jan 24, 2005 | 12:00 PM
EGPrelude's Avatar
Can i get a quote too please.
Old Jan 24, 2005 | 07:04 PM
engine_runner's Avatar
bump up nice
Old Jan 28, 2005 | 06:57 PM
Mr. Lucky's Avatar
Default Re: **S2000** Owners - BuddyClub Dampers!!! (engine_runner)
BC vs the Tein Flex?
Old Jan 31, 2005 | 04:06 PM
jdmstylesi's Avatar
pm's sent!
EViLSTAR
Mid-Atlantic (Sales)
Aug 6, 2012 06:38 PM
jdmjamesss
Honda S2000
Nov 24, 2010 04:44 AM
01integra-typer
Honda S2000
Aug 29, 2005 03:07 PM
YTYPER
Honda S2000
26
Nov 20, 2002 07:50 AM
