h22a head
So im real close to buying a jdm head for my h23 block.But just a couple of things crossed my mind a h23 block is obviously a bigger bore than the 2.2 so more fluid will be comming up from the block and then being crammed into the head which is smaller is that a problem, I can get it bored bigger if i need too. Im assuming i will need a new wirring harness for the head and a h22a ecu is that correct. If anyone has the h22 head on the h23 block and will like to share there thoughts about it would be greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlude04 »</TD></TR><TR><TD CLASS="quote">So im real close to buying a jdm head for my h23 block.But just a couple of things crossed my mind a h23 block is obviously a bigger bore than the 2.2 so more fluid will be comming up from the block and then being crammed into the head which is smaller is that a problem, I can get it bored bigger if i need too. Im assuming i will need a new wirring harness for the head and a h22a ecu is that correct. If anyone has the h22 head on the h23 block and will like to share there thoughts about it would be greatly appreciated.</TD></TR></TABLE>
ha 'obviously'
h23 and H22 blocks are the same bore.
Displacement has 2 variables: bore and stroke. you now have one eliminated. good luck figuring it out
ha 'obviously'
gulf imports
Jul 14, 2003 01:22 PM
