cam gear question
i wanted to ask you guys if cam gears would be ok to install with minor bolt ons such as: i/h/p/e/vafc/fpr?
will adding cam gears affect anything if anything at all?
thanks i wanted to from what you guys have experienced.
i can't say how much hp you could pick up....but by just putting them on none...
they are fine on stock cams, there is no reason why they wouldnt be........
you need to get on a dyno and have the tuner play with the timing a bit, he should be able to pull a few hp out here and there....but midrange will see good gains if you get a good tuner.....
