BuddyClub III+ < x < BuddyClub 4
I'm researching cams for the motor being built, and so far I was leaning to BCIII+ until I saw na200whp dynograph where they lost 20+whp after 7.5K RPM vs BC4 on a built B20 motor.
BC4 are good set of cams but I'm not planning on reving too high with the OEM 89mm crank.
My motor is not a B20 but 1.8LS/Vtec, 11.8 c/r.
Suggest me cams that make big power from 6K - 8.5K RPM where the revlimiter is going to be.
Or maybe I should stick with BCIII+ and hope my tuner can maximize the power output trough the RPM range...
i would say the bc4 since ur prolly top out of 12 c.r. and i think your tuner would be able to pull the max out of the motor, and then just keep a rev limiter or what not or a shift light to shift at your desired rpm, thats what i would do
something you should consider untill i'm proven wrong. well, common sense in a bit.
a 2.0L vs a 1.8L, of course, isn't the same.
meaning, the 2.0L breaths more. needing more air. now, something lilke the 1.8L does not.
i'm no cam spec genuis, but by the specs that the bc3+s have, its an ideal used for the 1.8L. whereas the bc4, by my understanding, requires more than a mild built motor. hence why motors like Tbone and na200hp are more than mild built, i.e. port work, high compression, etc.
now, crossing my finger but not changing on how I see these 2 cams. A local, hopefully is going to tired the bc4s on his stock bore 11.5 compression vs his bc3+s. I'm smacking him right now to do it,lol.
also, when purchasing these Buddy Club cams,lol.........make sure to inspect the cams, say like after a few thousand miles. And keep it up and let us know if anything changes.
i agree w/ Bert in that a 1.8 would make power to 8000-8300 rpm on bc3+ cams as where my b20 peaked at 7700. i feel if you are pushing 12to1 or very close go w/ bc4's . below that go bc3+'s . my power band looked identical between the two cams so as long as you have the compression to run the bc4's i would do it. keep in mind even if i set my rev limiter to 8200 i would still make more power than the spec3's
in that same dynograph you pointed out, the bc3's and the bc4's were neck and neck until the higher rpms...so make it easy on yourself and get bc4's. no one's forcing you to rev the cam higher than you want to rev it.
I see your point of view..
I will definetly have the compression (shud peak really close to 12.0:1), headwork, but bore will be at 81.25 mm... I wasn't really sure on how displacment affects overcammin the motor.
The car will be tuned with Hondata so setting a rev limiter at 8500 won't be a problem. On the other hand I'd love to see that BC4 vs BCIII on a 11.5 motor Bert is talking about.. but so far I'm convinced on getting the 4's over the III+.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O »</TD></TR><TR><TD CLASS="quote">also, when purchasing these Buddy Club cams,lol.........make sure to inspect the cams, say like after a few thousand miles. And keep it up and let us know if anything changes.</TD></TR></TABLE>
ummmmm....any particular reason why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 »</TD></TR><TR><TD CLASS="quote">
ummmmm....any particular reason why?</TD></TR></TABLE>
Newer cams. Want to find out how the cams hold up in the long run.
There is an explosion of cheap and inexpensive cams as of late. I too am curious to find out which category the BC's fall into. Cheap or inexpensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 »</TD></TR><TR><TD CLASS="quote">ummmmm....any particular reason why?</TD></TR></TABLE>
They are made in Taiwan, and most of the cams manufactured there seem to have some quality issues. We will have to see if BC is any different.
BTW, don't just inspect the cams, inspect the wiper pads on your rocker arms as well.
.</TD></TR></TABLE>
I would be very interested in the results of this test!!! Anytime line as to when??
.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">They are made in Taiwan, and most of the cams manufactured there seem to have some quality issues. We will have to see if BC is any different.</TD></TR></TABLE>
well, i find that statement to be somewhat misleading.....think about it, BuddyClub has an endurance race team that used these cams in there race cars, and we should be worried about the quality? hmmmmmm.....just sounds a bit weird. its like nobody can make a product anymore without people just assuming that the worst **** might happen. i think we'd all be very suprised if we really knew where half of the **** that we buy was manufactured....
Taiwan has increased significantly in their quality manufacturing process on everything since the 80's and 90's. China on the other hand are still catching up...
It boils down to each specific company and whether they have good quality control processes in place or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1div »</TD></TR><TR><TD CLASS="quote">Taiwan has increased significantly in their quality manufacturing process on everything since the 80's and 90's. China on the other hand are still catching up...
It boils down to each specific company and whether they have good quality control processes in place or not.</TD></TR></TABLE>
Werd
My D2 Coilovers have been nothing but great since I've gotten them. For those that haven't been paying attention...they are FULL COILOVERS, with 36 way dampening adjustability, shock length adjustability, AND you can find them for under 1000 bucks A SET. Look into Urban Import for those.
As for Buddy Club, when I spoke to E. Lo about some mild cams that would be an upgrade from ITR's, because I want a lil more mid range and want to stay under 800 bucks (basically not **** with my valvetrain), he suggested the BC3's. On a GSR they tried them on, it showed gains of 3-5 whp from 3000 - 6500 RPM. With something like 5-7 towards peak.
Werd
BoostedGSRBubble
51
Jun 18, 2002 10:00 AM
