60k on jdm h22 coming up
Old Dec 14, 2004 | 10:24 AM
esca's Avatar
Default 60k on jdm h22 coming up
i was wondering what kind of maintenance do i need when it hits the 60k mark.. i dont have the owners manual, because i got the car used.. and ive searched, and found a little on changing the water pump and the timing belt.. and thats it?
and would a honda dealership do it or will they not because its a jdm engine?
thanks for help
Old Dec 14, 2004 | 10:41 AM
CarpAngler's Avatar
I am pretty sure the timing belt and water pump dont need to be done until 90k and on 97 and up it is 110k. Reguardless i dont think that the honda dealership will have any problem with working on your car. What year is your car/motor?
Old Dec 14, 2004 | 11:14 AM
AndyD's Avatar
Default Re: 60k on jdm h22 coming up (esca)
If you are unsure of what was done to the motor, you should have the timing belt checked to see how much life it has left on it. That is an item you need to know how old it is and change it accordingly.
Other than that, you should be fine. No other things to upgrade.
Old Dec 14, 2004 | 11:35 AM
esca's Avatar
Default Re: 60k on jdm h22 coming up (AndyD)
cool thanks.. its a 92s with h22a
Old Dec 14, 2004 | 01:02 PM
AO's Avatar
AO
TIMING BELT FOR THE LOVE OF GOD!
I only wish I had checked mine.......
Old Dec 14, 2004 | 01:45 PM
vinuneuro's Avatar
60k mi service: oil change, coolant flush, tranny fluid/filter, alignment, valve adjustment, brakes taken out and cleaned,etc, fuel filter, plugs, wires,etc, there mgiht be some more. I had the dealer do this a couple months ago for my lude (still only at 60k miles, all orginal!).
Old Dec 14, 2004 | 02:17 PM
@ries's Avatar
ohhhh... how about a manual tensioner swap while you're at it?
Old Dec 14, 2004 | 04:48 PM
esca's Avatar
Default Re: 60k on jdm h22 coming up (@ries)
haha first car.. but whats a manual tensioner swap?
Old Dec 14, 2004 | 04:51 PM
satan_srv's Avatar
the timing belt change is at 90k, not 60k
Old Dec 14, 2004 | 04:53 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">haha first car.. but whats a manual tensioner swap?</TD></TR></TABLE>
Your H22 has an auto tensioner for the timing belt which is very prone to failure. H23s came with a manual tensioner that many people switch to because it's way more reliable.
Old Dec 25, 2004 | 04:51 PM
esca's Avatar
Default Re: 60k on jdm h22 coming up (Hawkze_2.3)
interseting.. thanks
nickysmalls
Honda Civic (2006 - 2015)
Jun 26, 2017 08:28 PM
backinblue92
Feb 17, 2015 05:32 PM
Nocturnal
Sep 6, 2005 10:35 PM
nver2
Feb 25, 2004 03:08 PM
311
Jul 20, 2002 10:08 AM
