B-series oil pans?
I was under the impression that the b18c's (not sure about b16's) had a deeper pan than the LS motors. Along with the deeper pickup (reason for the deeper pan). But they have the same bolt pattern. From what I know if your gonna put a vtec pan on nonvtec you gotta get the vtec pickup. Then again this is what i heard and not factual from me. Sorry, but could be right--then again maybe not.
holes line up, but the pick up is different, as is the baffling. The pickup reaches down further, to clear the main cap girdle the gsr has, but B16a does not. Just get a b16 pan
b16a and b18a/b are the same but b18c are not.
b18c oil pan's are deeper to compensate for the baffle and block gridle.
trust me on this, i was sent a b16 oil pan and when i went to install it on my b18c, it was too shallow, but the holes seems to line up.
so if you're using a b18c oil pan on a b16a, you WILL need the b18c's oil pickup.
naw thats my home girls sol. its actually for sale in the classifieds section. its a B16A DOHC sol. Joanne's ride.
