B-series oil pans?
Old Jan 3, 2002 | 04:40 PM
B_CRUZ!'s Avatar
Default B-series oil pans?
can i use a B18C1 oil pan on a B16 block? will the holes line up? sorry for the newbie questions.
<u>T|A</u>
[Modified by initial_B, 5:40 PM 1/3/2002]
Old Jan 3, 2002 | 05:12 PM
B19CivicHB's Avatar
Default Re: B-series oil pans? (initial_B)
I was told before that all B series vtec oilpan gaskets are the same so Im assuming the pan is the same. Again, I am only ASSUMING THIS.
Old Jan 3, 2002 | 07:15 PM
rainforest's Avatar
Default Re: B-series oil pans? (B18CivicHB)
yes it will work the b18c1 has better baffling on it also.
Old Jan 3, 2002 | 07:32 PM
SEFIxCivic's Avatar
you'll also need the gsr oil pick up and possibly the baffle.
Old Jan 3, 2002 | 09:47 PM
3rdGteg's Avatar
Default Re: B-series oil pans? (SEFI8LOxCivic)
ALL B-series oil pan bolt up.
Even LS ones will bolt up to b16 and GSR's.
Don't need nothing but the pan itself (+gasket) to make them fit.
Old Jan 3, 2002 | 10:52 PM
93LSivic's Avatar
Default Re: B-series oil pans? (3rdGteg)
I was under the impression that the b18c's (not sure about b16's) had a deeper pan than the LS motors. Along with the deeper pickup (reason for the deeper pan). But they have the same bolt pattern. From what I know if your gonna put a vtec pan on nonvtec you gotta get the vtec pickup. Then again this is what i heard and not factual from me. Sorry, but could be right--then again maybe not.
Old Jan 3, 2002 | 11:09 PM
VaporTrail's Avatar
New User
holes line up, but the pick up is different, as is the baffling. The pickup reaches down further, to clear the main cap girdle the gsr has, but B16a does not. Just get a b16 pan
Old Jan 4, 2002 | 12:28 AM
Snail EG's Avatar
b16a and b18a/b are the same but b18c are not.
b18c oil pan's are deeper to compensate for the baffle and block gridle.
trust me on this, i was sent a b16 oil pan and when i went to install it on my b18c, it was too shallow, but the holes seems to line up.
so if you're using a b18c oil pan on a b16a, you WILL need the b18c's oil pickup.
Old Jan 4, 2002 | 08:35 AM
B_CRUZ!'s Avatar
Default Re: B-series oil pans? (Snail EG)
i will use the B18C pan and pick up then. thanks for all the info. should everything bolt in okay with no mods to the pick up then? i'm just pulling off what i can from my B18C1 cause i bought a b16 shorty with no pan.
Old Jan 4, 2002 | 08:48 AM
Spade's Avatar
If you are doing that you might as well get the girdle. Basically swap everything below the main caps.
[Modified by Spade, 9:48 AM 1/4/2002]
Old Jan 4, 2002 | 09:00 AM
GReddySetGO's Avatar
why not just get a Moroso oil pan/pickup?
Old Jan 4, 2002 | 12:16 PM
B_CRUZ!'s Avatar
Default Re: B-series oil pans? (GReddySetGO)
because i already have a messed up B18C1 and a used B16A short block.
Old Jan 4, 2002 | 01:18 PM
roman420's Avatar
initial_B is that a B18C5 I see in your sol? sweet. ever thought about adding ram air induction on the hood above your intake filter?
Old Jan 4, 2002 | 01:39 PM
B_CRUZ!'s Avatar
Default Re: B-series oil pans? (roman420)
naw thats my home girls sol. its actually for sale in the classifieds section. its a B16A DOHC sol. Joanne's ride.
Old Jan 4, 2002 | 01:51 PM
DragII's Avatar
25 Year Member
yes they bolt on NO they will not work with out getting the pick up as well.
otherwise you will find out what oil starvation is all about
teri_vti
Dec 20, 2006 04:19 AM
iTzKeviN
Jan 8, 2006 06:30 PM
1SIKCRX
Jul 7, 2004 07:59 PM
chock_r
Jun 30, 2002 08:33 AM
