Crank pully nut
Yea I couldnt get it off with the snap on impact. I use a socket wrench with a bigass pipe on the end to break it loose.Both breaker bars were harbo freight that probably why they broke.
unless you have a REALLY high powered impact gun with a big air compressor that can keep up with the flow then you need a 6 foot peice of pipe and the honda tool that holds the crank pulley from turning
I tried many impact guns and they were just plain pointless. Just use a socket and a breaker bar and apply constant pressure with the car in 5th gear if its a manual. Dont just jerk the bar or it wont come out. Constant pressure.
Yeah my impact wont get it loose ......
i havent tried the breaker bar yet because i dont have the pully holder.
oh well , where can i get that pully tool???
heres the key...PB BUSTER its the best penetrating oil money can buy...spray it on there give it a few min and do it again...get that impact gun back on there and watch it come off...i removed all 3 of my cars crank pully nuts by hand with this stuff...19mm socket and a 2 ft breaker bar...craftsman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRELUDE_SR_V »</TD></TR><TR><TD CLASS="quote">Yeah my impact wont get it loose ......
oh well , where can i get that pully tool???</TD></TR></TABLE>
No need for a pulley holder. just take off the flywheel cover on the bottom of the tranny. Then put a long screwdriver in there to hold the crank from turning. Works perfect and saves you $, but if you have the money buy a pulley holder im sure its well worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix »</TD></TR><TR><TD CLASS="quote">
No need for a pulley holder. just take off the flywheel cover on the bottom of the tranny. Then put a long screwdriver in there to hold the crank from turning. Works perfect and saves you $, but if you have the money buy a pulley holder im sure its well worth it.</TD></TR></TABLE>
This is what i do when I take out my crank pulley. Or you can take out your starter and place your screw driver there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRELUDE_SR_V »</TD></TR><TR><TD CLASS="quote">i had thought about that (puting the car in gear vs. a pully holder ,. is that safe for the tranny?</TD></TR></TABLE>
Putting it in gear will not hold your crank from turning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRELUDE_SR_V »</TD></TR><TR><TD CLASS="quote">Impact at 150psi did the trick.....
Awesome...Ive never met a crank pulley bolt that i couldn't get off with a breaker bar and a screw driver in the flywheel..
</TD></TR></TABLE>Awesome...Ive never met a crank pulley bolt that i couldn't get off with a breaker bar and a screw driver in the flywheel..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luderacer22 »</TD></TR><TR><TD CLASS="quote">
Putting it in gear will not hold your crank from turning.</TD></TR></TABLE>
Really? Wow. Please elaborate on why that is.
Pirate
Pirate
deckster333
May 12, 2018 05:38 AM
memorybox
16
Sep 28, 2006 10:00 AM
