auto tranny slippage
Old Dec 13, 2004 | 09:58 PM
130R's Avatar
Default auto tranny slippage
fixed
Modified by carbing'ed at 8:31 PM 1/26/2005
Old Dec 13, 2004 | 10:19 PM
Lord Helmet's Avatar
Default Re: auto tranny slippage (carbing'ed)
checked the tranny oil level lately?
sounds like the torque converter or the tranny itself is gone. a replacement/rebuild is in order.
Old Dec 13, 2004 | 10:26 PM
130R's Avatar
Default Re: auto tranny slippage (sleeperciv)
how much would that cost? my tranny isnt leaking anything, so fluild level should be as it always was right?
Old Dec 13, 2004 | 10:29 PM
130R's Avatar
also, this happened suddenly after my smog test. does anyone know if they could have done something? like the timing or whatever
Old Dec 13, 2004 | 11:06 PM
130R's Avatar
Old Dec 13, 2004 | 11:17 PM
_Cyclone_'s Avatar
No, it's not because of the smog test. Did you try any other gear positions, like D3 or the 1-2?
Before you go replacing or rebuilding, or even sweating about paying for that stuff... pull out your red dipstick with the car on, in park, and warm on a flat surface. Wipe it with a CLEAN towel, put it back in, pull it out again and check your reading. If it's low, get a funnel and pour some Honda ATF through the dipstick hole a little bit at a time, checking frequently. Do this with the car ON by the way.
Old Dec 13, 2004 | 11:23 PM
130R's Avatar
Default Re: auto tranny slippage (CycloneBlue_1.6EL)
will i hurt the tranny anymore if i drive it for the next 2 days? i have finals tomorow and wednesday
Old Dec 14, 2004 | 01:44 AM
murmur9's Avatar
Unn...I think it would be smart of you....and probably a lot cheaper than just running to the shop to get a new tranny...
Search on here,,,find a how to, for changing your tranny fluid, its easy ****, just like oil. I believe you have a filter too you should change, but just try the fluid first. Drain, refill...its around 2.5-2.9 qts i think? someone correct me please.
you should do regular maintainance on your car, come on. lol good luck.
you can get an auto tranny on the classifieds here on HT, search them...do a search. if you know how to...put it in yourself. or take it to someone. they usually charge about 50-70 an hr.
Old Dec 14, 2004 | 04:29 AM
Cuong-nutz's Avatar
If the fluid is way lo, that **** will rev and rev till there's fluid is forced into the torque converter. If there's **** left, your tranny's probably fried by now, if not, try a tranny flush and hopefully you can clean out all that crud and top off with new ATF from Honda. If that doesn't help, a rebuild or new tranny is in order.
Old Dec 14, 2004 | 08:06 AM
alotawatts's Avatar
1 case (12 qtrs) of Honda ATF $50.00 1 new drain bolt washer $1.00
Do a search on the flush procedure. Basically you jack up front end of car and drain-add fuid and run thru the gears several times to cycle new fluid thru the torque converter.
If you still have grief after a flush it could be the trans linear solenoid. If the trans fluid is never changed these solenoids get contaminated/clogged. Easy to replace yourself but = aprox $150.
Old Dec 14, 2004 | 11:18 AM
130R's Avatar
Default Re: auto tranny slippage (murmur9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote">
you should do regular maintainance on your car, come on. lol </TD></TR></TABLE>
yeah, well im not a big fan of automatics, and this car will be passed to my sis in a matter of months. there is a dipstick? a red one? where might i find that?
Old Dec 14, 2004 | 11:24 AM
130R's Avatar
i found a yellow dipstick in the back of the tranny, the color of the fluid looks grayish, is that bad? doing a test now to see if i have enough fluid
Old Dec 14, 2004 | 11:27 AM
130R's Avatar
looks like i have enough fluid in there, and i correct myself, the fluid is actually darkish brown like a mahogany type thing
Old Dec 14, 2004 | 01:02 PM
130R's Avatar
Old Dec 14, 2004 | 01:31 PM
alotawatts's Avatar
...Should be Pink......do a flush. Use Honda ATF.
Old Dec 14, 2004 | 07:26 PM
130R's Avatar
so for sure it's the tranny fluid then?
Old Dec 14, 2004 | 08:20 PM
_Cyclone_'s Avatar
Yeah, seems like you have the right one, I thought they had red dipsticks for tranny. Anyways, as long as you know which dipstick is your engine oil, and you're NOT reading that one... it's the tranny.
You're tranny fluid is probably burned, does it smell burned? If you don't really know alot about cars, I'd take it to your nearest Honda dealership for a tranny flush and filter. Up here in Canada, it only costs about $89.99CAD at my local Honda dealership. If it still does it after that, probably time for a rebuild or swap.
norcali707
Honda Civic (2001 - 2005)
Feb 20, 2012 06:01 AM
ls-vtEK4
Transmission & Drivetrain
10
Jan 23, 2009 06:31 AM
stevescivic
Dec 16, 2007 06:38 PM
civicmon
Feb 17, 2004 01:44 PM
EL-Driver
Mar 16, 2003 08:00 PM
