distributer not sparking
Old Dec 13, 2004 | 09:50 PM
BOMBCRU's Avatar
Default distributer not sparking
the search hasnt really helped much
ok i got a 90 accord with a f23 in it
ive tried 3 distributers none will fir
itll spark when u hit the icm(ignitor) yellow green wire
ive tried jumper wire to the distrib to the computer and still no fire
im not getting a pulse to let it fire
ive even changed out the main fuse and it still wont lit up
any one got a schimatic or have any idea to try,
at this point ive already put a hole in the dash next thing is a road flare
Old Dec 13, 2004 | 10:09 PM
TIRENECK's Avatar
Default Re: distributer not sparking (BOMBCRU)
if it fired up before than its either the distributor or the spark plug wires.
triple_s1x's Avatar
Shot in the dark here, how are your grounds? Also check your ecu and the related fuses. Is your fuel pump priming?
Old Dec 14, 2004 | 12:15 AM
BOMBCRU's Avatar
Default Re: distributer not sparking (triple_s1x)
ive checked all fuses, only seen one ground, ive replaced the ecu with the chipped p28 for that motor
no ideas
Old Dec 14, 2004 | 12:16 AM
BOMBCRU's Avatar
Default Re: distributer not sparking (TIRENECK)
ive tried a few sets of wires
it does fire when i ground out the icm though but that cant be grounded its a pulse ground or something
it does have fuel
it only has lake 20 fuses int he whole car and there all good
Old Dec 14, 2004 | 02:38 PM
BOMBCRU's Avatar
bump
Old Dec 15, 2004 | 04:44 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOMBCRU &raquo;</TD></TR><TR><TD CLASS="quote">it does fire when i ground out the icm though but that cant be grounded its a pulse ground or something</TD></TR></TABLE>So that means the ignitor & coil are OK. Sounds like the trigger signal from the ECU to the ignitor isn't good. Trace that wire back to the ECU & see if it's broken or shorted somewhere. Or maybe that pin isn't seated into the ECU tightly?
Old Dec 15, 2004 | 12:25 PM
BOMBCRU's Avatar
Default Re: distributer not sparking (JimBlake)
never thought about the seating, but i did make a jumper wire from the dist to a21 and a22 the yellow/green and nothing happened, unless one of the other wires controls that output o the icm????????????
Old Dec 15, 2004 | 12:47 PM
JimBlake's Avatar
I don't really know the differences between generations of ECU, but on my '95 Integra the yellow/green wire is the signal from ECU to ignitor. (Why does it go to 2 ECU pins??)
Old Dec 16, 2004 | 03:47 PM
BOMBCRU's Avatar
haha i have no idea, but it is a paint in tha *** to keep pulling the ecu from under the capret everytime hehe
buddy think the positioning sencer wire is messed up so imma try to bypass that that is what causes the pulse
JasonST
Apr 10, 2024 10:40 AM
georgen316
May 18, 2014 12:57 PM
JasonST
Mar 22, 2013 08:06 AM
CLE
11
Aug 1, 2006 08:23 PM
BOMBCRU
Dec 14, 2004 02:35 PM
