CEL code 3 on in a 95 cx w/ b16. will vtec engage?
Old Dec 13, 2004 | 06:42 PM
gsser's Avatar
Default CEL code 3 on in a 95 cx w/ b16. will vtec engage?
i have a 95 cx with a b16 sirII swap. it is currently throwing a CEL that i found out was because of my lack of a map sensor. it runs in safe mode and gets terrible gas mileage. when vtec should kick in it feels flat with no noticeable rise in power. i am wondering if vtec is not kicking in with my check engine light on? can anyone help me out with this? thanks. tim
Old Dec 13, 2004 | 07:31 PM
PrettyLude's Avatar
no vtec will not engage
Old Dec 14, 2004 | 01:33 PM
gsser's Avatar
Default Re: (PrettyLude)
thanks. throttle body is coming in a few days with a map sensor on it so i should be ok.
Old Dec 14, 2004 | 01:43 PM
gsser's Avatar
Default Re: CEL code 3 on in a 95 cx w/ b16. will vtec engage? (gsser)
has anyone had this happen to them before? their intake manifold on their swap not coming with a map sensor? i can't be the only one. any quick fix? thanks. tim
Old Dec 14, 2004 | 02:41 PM
Kamin's Avatar
JDM engines have the MAP sensor attached to the firewall, you can just take the one off your stock throttle body and run a vacuum line off the top of the JDM engine's throttle body to the old map sensor.
Old Dec 14, 2004 | 03:58 PM
ekgcool's Avatar
Default Re: CEL code 3 on in a 95 cx w/ b16. will vtec engage? (Kamin)
Doesnt the SIR II come with the MAP on the T-body? I thought only OBD-0 and the 1st series of OBD-1 have the MAP on the firewall. If you have your old T-body from the CX motor, just use that one. If the t-body on the B16 has a nipple close to the throttle rotor, then just use a vaccum hose and attatch it to the nipple on the MAP. If there is the hole on top of the t-body, then just screw it in. Either way, a MAP is a MAP. And yes, no VTEC! SAFE MODE!
Old Dec 14, 2004 | 05:42 PM
gsser's Avatar
Default Re: CEL code 3 on in a 95 cx w/ b16. will vtec engage? (tekracer)
spare plug has a red wire and a black/yellow wire
Old Dec 14, 2004 | 06:47 PM
gsser's Avatar
ok, spare plug goes to the evap purge solenoid, red wire and black/yellow wire. ran vacuum hose from charc canister to eps and from eps to intake manifold. plugged loose plug into evap purge solenoid. now that thats taken care of, how exactly do i hardwire my map sensor to my ecu?
i have 3 wires coming from my map sensor plug that is detatched from the harness that is on the motor. 1. power 2. signal 3. ground.
1. yellow/red - power
3. red/green - signal
2. green/white - ground
do i have this right?
EK9ED
10
Oct 26, 2009 04:43 PM
TheIceMan
12
Dec 23, 2005 04:08 AM
kechup2eg6
Aug 10, 2005 07:47 PM
IVI
Aug 26, 2004 01:04 PM
handa
13
Jun 28, 2004 06:31 AM
