Changed injectors now no start!!!
Old Dec 13, 2004 | 04:32 PM
tolowhb's Avatar
Default Changed injectors now no start!!!
Ok guys I am taking the turbo stuff off my d16z6 and tonight I had to pull the dsm injectors. Now I put the stock ones back in and now the car just turns over but will not fire. I dont know what it could be please help me!!!
Ricey McRicerton's Avatar
Default Re: Changed injectors now no start!!! (tolowhb)
Did you remove the resistor box?
Old Dec 13, 2004 | 04:42 PM
tolowhb's Avatar
Default Re: Changed injectors now no start!!! (Ricey McRicerton)
Yes I did.
Old Dec 13, 2004 | 04:43 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb &raquo;</TD></TR><TR><TD CLASS="quote">Ok guys I am taking the turbo stuff off my d16z6 and tonight I had to pull the dsm injectors. Now I put the stock ones back in and now the car just turns over but will not fire. I dont know what it could be please help me!!!</TD></TR></TABLE>
Check and see if you have fuel going through the injectors.
remember the 3 things that make a car start, spark, fuel, and timing.
Old Dec 13, 2004 | 04:45 PM
tolowhb's Avatar
Default Re: Changed injectors now no start!!! (xtremeazian)
How can I check to see if there is fuel going through?
Old Dec 13, 2004 | 04:55 PM
tolowhb's Avatar
I did forget the resistor box on when I first put my stock injectors in, could I have fried something????
Old Dec 13, 2004 | 04:56 PM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb &raquo;</TD></TR><TR><TD CLASS="quote">I did forget the resistor box on when I first put my stock injectors in, could I have fried something????</TD></TR></TABLE>
Injector drivers on the ecu
Old Dec 13, 2004 | 04:58 PM
tolowhb's Avatar
Default Re: Changed injectors now no start!!! (civic-4-ges)
ummm that doesnt sound good..........
Old Dec 13, 2004 | 05:05 PM
But that may not be the issue, not sure what running extra resistance on an ECU will do
Old Dec 13, 2004 | 05:08 PM
tolowhb's Avatar
See heres the thing. When putting in the dsm injectors you are supposed to hook a bunch of yellow wires coming off the ecu to the resistor box. Well anyways I forgot to unravle the wires before I tried to fire up the car, would this be enough to burn up my ecu? I can hear my fuel pump turn on but like I said the car will not fire.
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">
remember the 3 things that make a car start, spark, fuel, and timing. </TD></TR></TABLE>
You do mean, spark, fuel, air. Right?
Assuming a brick didnt crush your intake pipe, we can assume you have air.
Checking your spark plugs is easy enough.
If you can disprove fault in air + spark, its probably going to point to fuel.... Like we say at work.......eliminate the question.
Old Dec 13, 2004 | 05:18 PM
tolowhb's Avatar
Default Re: Changed injectors now no start!!! (jlacoy82)
Yeah, this sucks
Old Dec 13, 2004 | 05:29 PM
tolowhb's Avatar
From what I have read, it seems the wires that I am talking about are constant power from the ecu???
Old Dec 13, 2004 | 05:37 PM
tolowhb's Avatar
These are the wires I am talking about:
Old Dec 13, 2004 | 05:47 PM
93civicEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">
If you can disprove fault in air + spark, its probably going to point to fuel.... Like we say at work.......eliminate the question.</TD></TR></TABLE>
Just to let you guys know, Its fuel, spark, and compression, which makes an engine run. bump to help this guy
Old Dec 13, 2004 | 05:53 PM
tolowhb's Avatar
Keep me up!!!
Old Dec 13, 2004 | 05:58 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Changed injectors now no start!!! (93civicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicEX &raquo;</TD></TR><TR><TD CLASS="quote">Just to let you guys know, Its fuel, spark, and compression.</TD></TR></TABLE>
Try and start an engine in vacuum, chatch. Compression helps make power, but it's not necessary for a running engine. Oxygen is what burns. You're not getting any oxygen without air. Period.
Old Dec 13, 2004 | 06:01 PM
jlacoy82's Avatar
71.192.16.183
My fuel oil background finally comes in handy! 3 elements to combustion, air, fuel, spark! weeeeeee
Old Dec 13, 2004 | 06:02 PM
tolowhb's Avatar
ugggh
Old Dec 13, 2004 | 06:03 PM
shorty's Avatar
its a sign to keep the turbo on
Old Dec 13, 2004 | 06:09 PM
Br1anPham's Avatar
Yes, I'm sure he means air, fuel, and spark.
wwolf771177
Jan 8, 2012 08:57 PM
jdmsohc94
Apr 13, 2008 03:22 PM
b16a27
Sep 19, 2007 04:35 PM
DeviousCTR
May 10, 2006 03:31 PM
Hayasa15
Jan 28, 2002 07:24 PM
