B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES
Old Dec 13, 2004 | 03:05 PM
swiftstyles's Avatar
Default B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES
sup, I had my b20/vtec in for over 25,000 miles with non-vtec timming belt and water pump. I decieded to change out the pump and belt for vtec ones. What is all the hype about in doing this. It didn't make a different, I mean I didn't expect to gain more horsepower or anything but why do people always talk about it needing to be done on a b20/vtec setup. I never had any problems with over heating or anything before. It ran fine.
Old Dec 13, 2004 | 03:31 PM
carbed_rex's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (swiftstyles)
I'm not sure about newer water pumps but the older non vtec ones have 19 teeth( I believe) and the vtec ones have 22 teeth. The reason for the larger pulley is to spin it slower. Since the vtec engine redlines higher, honda didn't want the bearing on the pump to fail. It certainly won't increase or decrease hp but using a non-vtec w.p. to wail to 8-10k won't help its life expectancy.
Old Dec 13, 2004 | 03:48 PM
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (carbed_rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbed_rex &raquo;</TD></TR><TR><TD CLASS="quote">It certainly won't increase or decrease hp but using a non-vtec w.p. to wail to 8-10k won't help its life expectancy.</TD></TR></TABLE>
Yea thats what I also came to a conclusion on.
Old Dec 13, 2004 | 07:38 PM
mmuller's Avatar
Mad Scientist
its actually because non-vtec water pump cavitates after 7500rpms.
i guess the bearing thing too but..
Old Dec 13, 2004 | 07:55 PM
Dan GSR's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">its actually because non-vtec water pump cavitates after 7500rpms.
i guess the bearing thing too but..</TD></TR></TABLE>
cavitate: The sudden formation and collapse of low-pressure bubbles in liquids by means of mechanical forces, such as those resulting from rotation of a marine propeller.
yup, the larger gear on the VTEC water pump will make the pump spin slower
Old Dec 14, 2004 | 01:01 AM
LSvtec03's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (Dan GSR)
i know the vtec water pump has more teeth on it...so i would assume the vtec pumps flow more water/oil, making the motor more reliable.
Old Dec 15, 2004 | 04:59 AM
Dan GSR's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (LSvtec03)
actually, with a VTEC water pump, its actually slower, the water isn't pumped as fast
Old Dec 15, 2004 | 05:57 AM
Used2beAb16's Avatar
like they said, the water pump has more teeth, turns slower, and this prevents cavitation at high rpms. Also u need the belt to match the pump
Old Dec 24, 2004 | 01:26 PM
ResponseRacerX's Avatar
did you switch out the oil pump also?
Old Dec 24, 2004 | 02:44 PM
Dan GSR's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (ResponseRacerX)
no need, all newer oil pumps are the same
Old Dec 25, 2004 | 12:42 PM
...thats what i thought too, but a butt load of people insist on changing to a b16 or type R oil pump. I have a B20(2.0) logically wouldnt that oil pump flow better that a b16(1.6) oil pump?
I got a new one...I heard you not suspose to "free rev" a B20 vtec or an LS Vtec.
Has anyone heard of this or do i just hang out with some pot headed racers?
Old Dec 25, 2004 | 01:15 PM
Flexmyrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">no need, all newer oil pumps are the same</TD></TR></TABLE>
anyone else know if this is a fact
Old Dec 30, 2004 | 06:07 AM
stehigs321's Avatar
So are gsr water pumps and type r water pumps identical??
Old Dec 30, 2004 | 06:11 AM
Dan GSR's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (Flexmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexmyrex &raquo;</TD></TR><TR><TD CLASS="quote">
anyone else know if this is a fact</TD></TR></TABLE>
look it up for yourself, all the part numbers are the same
Old Dec 30, 2004 | 06:12 AM
Dan GSR's Avatar
Default Re: B20/VTEC'ERS WHY CHANGE OUT WATER PUMP AND TIMMING BELT TO VTEC ONES (stehigs321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stehigs321 &raquo;</TD></TR><TR><TD CLASS="quote">So are gsr water pumps and type r water pumps identical?? </TD></TR></TABLE>
yes, both are 22 T
Old Dec 30, 2004 | 06:15 AM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ResponseRacerX &raquo;</TD></TR><TR><TD CLASS="quote">...thats what i thought too, but a butt load of people insist on changing to a b16 or type R oil pump. I have a B20(2.0) logically wouldnt that oil pump flow better that a b16(1.6) oil pump?
Has anyone heard of this or do i just hang out with some pot headed racers?</TD></TR></TABLE>
if you have a B20B, or B20Z, you already have a "ITR" oil pump
jdmbeegee
11
Jun 3, 2007 06:38 PM
Dr.Octagon
Jun 12, 2006 07:42 AM
tinkerbell
Sep 17, 2003 05:05 AM
teg92
Dec 6, 2002 06:20 PM
