!help! leaking 4 quarts in seconds!!!!!
Old Dec 13, 2004 | 02:19 PM
Rainville's Avatar
Default !help! leaking 4 quarts in seconds!!!!!
we have narrowed the leak to the oil filter. the gasket mating area is clean. any thoughts.
Old Dec 13, 2004 | 02:22 PM
evad's Avatar
Default Re: !help! leaking 4 quarts in seconds!!!!! (Rainville)
Maybe the oil filter is double gasketed.....need more info
Old Dec 13, 2004 | 02:23 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
make sure there are no two gaskets on the surface, sometimes the old one gets stuck.
stan
Old Dec 13, 2004 | 02:26 PM
Rainville's Avatar
Default Re: !help! leaking 4 quarts in seconds!!!!! (Stan D)
no double gasket already checked that
Old Dec 13, 2004 | 02:30 PM
smart monkey's Avatar
is the gasket missing. also do you have the right sized oil filter to mate to the block.
drdisco69's Avatar
Try a different filter?
Old Dec 13, 2004 | 02:58 PM
evad's Avatar
Default Re: !help! leaking 4 quarts in seconds!!!!! (smart monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">is the gasket missing. also do you have the right sized oil filter to mate to the block.</TD></TR></TABLE>
Aren't all the honda filters the same size?????
Old Dec 13, 2004 | 03:32 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainville &raquo;</TD></TR><TR><TD CLASS="quote"> the gasket mating area is clean.</TD></TR></TABLE>
Meaning there are no chips or gouges on the surface that the rubber ring touches? if the surface is fine and the threads are fine, you're left with a problem with your oil filter itself. Make sure you are oiling the rubber ring before threading it on and make sure you don't over tighten it or it will deform the rubber ring. Not all Honda filters are the same size, but most are the same. The OEM filters have been changed to a much smaller body but the thread and rubber ring size are the same. Make sure you are using an OEM filter until you get to the bottom of the problem, and try more than one filter incase the filter itself is leaking.
Old Dec 13, 2004 | 03:34 PM
drdisco69's Avatar
Default Re: !help! leaking 4 quarts in seconds!!!!! (evad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evad &raquo;</TD></TR><TR><TD CLASS="quote">Aren't all the honda filters the same size?????</TD></TR></TABLE>
Nope. Legend has a larger thread in the middle.
Old Dec 13, 2004 | 03:40 PM
evad's Avatar
Default Re: !help! leaking 4 quarts in seconds!!!!! (drdisco69)
So you really do learn something new everyday
Old Dec 13, 2004 | 03:51 PM
Jaker's Avatar
Its not the oil filter. Its the oil pressure sender above the filter. Its either really loose, or its not even there. I learned this one the hard way.
Old Dec 13, 2004 | 03:52 PM
drdisco69's Avatar
Yeah, the Legend filter has larger threads and a larger gasket area.
Don't forget the Insight filter, which is like 2" by 3". So cute!
Old Dec 13, 2004 | 04:33 PM
evad's Avatar
Mmmmmmmmm....................EDUCATION!!!!
Old Dec 15, 2004 | 06:54 PM
Rainville's Avatar
i've started my car twice and drove it 15 miles and no more problems, so far. i'm on the third filter now, so we'll see.
Old Dec 15, 2004 | 07:11 PM
HondaKPX's Avatar
AHHHH!!! no dont drive if your loosing oil that fast. hope you wanna do a motor swap
Old Dec 17, 2004 | 07:08 AM
Rainville's Avatar
Default Re: !help! leaking 4 quarts in seconds!!!!! (HondaKPX)
I should've been more specific, when i drove it there were no leaks.
tom91ita
May 31, 2005 11:24 AM
gsr-2nr
Jun 2, 2004 11:47 PM
the_0ne
38
Mar 22, 2004 08:18 PM
cokinut
Oct 13, 2003 06:23 PM
Dirt
Feb 25, 2003 11:29 AM
