What bearings to use??
Old Dec 13, 2004 | 01:06 PM
Del_Sol_s's Avatar
Default What bearings to use??
what crankshaft bearings should i use on a b16 block sleeved and the crank is polished. It is gonna be using eagle rods and a stock cranks just polished.
thanks
Old Dec 13, 2004 | 01:07 PM
Louie_EM1
Guest
Posts: n/a
Default Re: What bearings to use?? (jdmvic)
ACL is never a bad choice.
Give em to your machine shop so they can measure it.
By the way, since you're in Chicago, who's doing the machining?
Old Dec 13, 2004 | 01:10 PM
Del_Sol_s's Avatar
one6 sent out the block for sleeving and they told me to measure it out too..But still not sure on which ones to use.
Old Dec 13, 2004 | 01:15 PM
Louie_EM1
Guest
Posts: n/a
Default Re: (jdmvic)
I like One6 but I suggest taking that block to APEX, they are a great machine shop, I'm getting my build done there quite possibly in the next week (going with ACL bearings, also using a b16, and also using a refinished stock crank.
PM me for their number if you're interested.
If you've heard of AMS and their project cars, well APEX has made several of their blocks in the past, and I've seen some secret projects from different shops in the local area and it's great work that they do (30+psi). They are located on 83/archer about 25mins SOUTH of One6.
There a few H-T members that have gone through with APEX also, and I have gone through them twice myself personally.
Old Dec 13, 2004 | 01:16 PM
Del_Sol_s's Avatar
well the whole motor is done..its just that i need bearings to finish it up..Ive built up a few other cars already and had my blocks done by apex.
Old Dec 13, 2004 | 01:19 PM
Louie_EM1
Guest
Posts: n/a
I'd personally just take it to them then. I mean have them measure it and assembly the bottom and call it a day.
They'll charge probably around 50 bucks; but that's just me I mean I don't have any fancy measuring tools..
But yea I've used ACL in the past and I like them.
Sorry can't be more of a help than that.
Del_Sol_s's Avatar
where can i get a set of acl bearings? i dont feel like taking the block anywhere else and i just wanna get the bearings..since i already have the measurements.
Old Dec 13, 2004 | 01:20 PM
Del_Sol_s's Avatar
got a number to the apex place? maybe ill stop by there tonite.
Old Dec 13, 2004 | 01:25 PM
Louie_EM1
Guest
Posts: n/a
You have PM
Old Dec 13, 2004 | 01:31 PM
Del_Sol_s's Avatar
they quoted me $240 to assemble a short block..and no charge to measure it.
Old Dec 13, 2004 | 01:36 PM
Archidictus's Avatar
Unceasing Measure
You can't go wrong with OEM.
ls_vtec_da
K Series
Nov 19, 2010 10:28 PM
mugen mj5
Sep 15, 2009 03:10 PM
nytosc
10
Apr 7, 2009 05:48 PM
johnls
Aug 4, 2007 10:47 PM
swpdb16
Mar 2, 2004 12:45 PM
