where to get a battery cable
Old Dec 13, 2004 | 10:57 AM
EFin' Kyle's Avatar
Default where to get a battery cable
ok the red battery cable has a short in it. i took my car to autozone and the guy there said i have to go to the dealer and buy one from there and it will be like $110 . does anybodyy have one or know where i can get one.please help i need my car to get around to school and to find a job. tahnk you
-Kyle
(p.s. i have a 1990 crx si with a b16 in it)
Old Dec 13, 2004 | 11:06 AM
92integra_gs's Avatar
try ebay... usually they got it ...
either that or just go to the junk yard and get a decent one off another car
Old Dec 13, 2004 | 11:09 AM
EL Vap133's Avatar
Default Re: where to get a battery cable (AutoX wannabe)
I would try the junkyard as well...
Old Dec 13, 2004 | 11:19 AM
Outsane's Avatar
Default Re: where to get a battery cable (EL Vap133)
they have cables at Autozone..
Old Dec 13, 2004 | 12:16 PM
EFin' Kyle's Avatar
Default Re: where to get a battery cable (Outsane)
i went to autozone they said that they dont have that one for my car i would have to go to the dealer. i am thinking about kregan or sumthin b4 i go to the junkyard
Old Dec 13, 2004 | 05:22 PM
doublethink's Avatar
just make your own man. 4 awg wire, some wire loom (1/2 inch) , some ring terminals and a new battery terminal. it can all be had for like 20 bucks total.
its 100 times easier then engine work, imho.
just run one wire to the starter and one to the fuse box under the hood. copy exactly what the stock setup was, and youll be fine. if you dont have anything to crimp (flatten) the ring terminals, you can use a shop vice or a 'c-clamp'.
then, if you wan to get really tricky, get some brown 4 awg, and redo the under the hood grounds too, to make them match width.
or you could get a "grounding kit" on ebay, which is wire and ring termianls, but they charge too much.
if you cant find a place that has wire on spools for you, then go buy an amplifier installation kit, or go to home depot. just dont get house wire, bc it wont bend like automotive wire. be careful of that.
youll feel better having done it yourself, its a waste to buy a new wire from a dealer.
Old Dec 13, 2004 | 09:19 PM
EFin' Kyle's Avatar
Default Re: where to get a battery cable (doublethink)
i bought one from napa for $4 didnt solve problem tho. my car still has hardly anypower. if i turn my headlights on and hit the brakes the cd player turns off. i just got a new alternator and a new positive cable and a new battery. could it be that i need a bigger battery? this problem is irritating me
Old Dec 13, 2004 | 09:50 PM
how did the thick 12 volt battery wire get shorted without blowing a fuse?
if the battery is hooked up right, and teh grounds are all clean and hitting bare chassis, then your alternator is not charging the battery, so the engine is runnign off nothing but the battery, and slowly your accessories in the car will start to die as the voltage on their inputs drops below 12 volts...
chck the tension on the alternator belt, double check that the little 10mm nut on top of the alternator is all the way down and tight. see what else may have shorted when the thick wire went.
if its not something silly like that, your alternator might be screwed, which wold suck since its fairly new like you said, but try simple and cheap stuff first like double checking connections, things are plugged all the way in, belt is tight, etc.
i was lazy one time and the 10mm on the alternator was loose and it would lose power from time to time.
good luck.
Old Dec 14, 2004 | 12:58 AM
LSvtec03's Avatar
i just got 19 inch 4 gauge wire with ring terminals from meijer for 3.99
$110 from the dealer?
Old Dec 14, 2004 | 01:48 PM
EFin' Kyle's Avatar
should i tighten the alternator belt as tight as i can get it or just kinda tight? it has a little room to move up and down but not alot. should i tighten it or no?
cubnsensation
22
Feb 23, 2018 09:11 AM
KraZyCHOWMEIN
May 26, 2010 09:06 AM
Metal Head
Audio / Security / Video
Mar 15, 2009 07:21 AM
dpdawson
Honda Civic (2001 - 2005)
Dec 1, 2008 09:17 AM
simonEp3
Jun 25, 2008 01:11 PM
