B17A1 question
I did a B17 swap in my 93 Del Sol using JDM obd1 P72 ECU. The problem is the car not seem to pull at all, I feel like the timing is retart. When I try my friend P28, and a chipped P72 w/out knock sensor the car run way better than the JDM P72. My question is...it is the knock sensor that cause all this problem?
Thanks for any help
Thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso »</TD></TR><TR><TD CLASS="quote">Gotta remember that the p72 will be looking for the butterflies. </TD></TR></TABLE>
the p72 DOES NOT look for butterflies. it can control them and is optimized to run with them.
so the sencondary butterflies only exist on the 94+ GSR manifold? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUB-96EK »</TD></TR><TR><TD CLASS="quote">butterflies are in the manifold of the obd2 gsr's... just get another ecu
I may have a stock '92 GSR ecu if u want... it's a p61</TD></TR></TABLE>
How much do you want to sell your stock 92 GSR ECU email me at nguyend@hawaii.rr.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">Is there anyway to dissable the sencondary butterflies in the ECU so it doesn't look for it?</TD></TR></TABLE>
Install the patented "Butterfly net". Hondata make it.
I'm a little confuse now....I have a P72 which control IAB, and I have a B17 manifold which does not have an IAB or secondary runner? So without an IAB I'm lossing some low end torque...In order to make the P72 happy I need to get all the IAB system from the B18C1 and hook it up? or like "Ricey McRicerton" said to install patented "Butterfly net" what is that anyway and where can I find that?
Thanks
Thanks
Why dont you just run an ITR chipped P28? You won't be able to slap on the GSR manifold without swapping the whole head. You are just running an ECU not made for the B17.
wait a minute...I got carried away with all these IAB stuff...there is one thing that I don't understand...when I tried the P72 on two of my friend car w/B16 (one is 92-95 JDM B16 and the other is B16A2) both car ran find without hesistation. I've been searching on H-T about IAB topic and everyone is saying that IAB only have on B18C1 and H22. So why does the B16 run find with my P72 and i can't run my B17 with it?
BTW: I've tried both P28 and a chipped USDM p72 and they both run better on my car. Well I can get a P28 and chipped it out, but I just want to know why my car bogging out badly in low end. Could it be the VTEC x-over point is too low on the JDM P72 (I believe the x-over point is about 4500-5000 rpm; not too sure if this ECU was chipped though
on a budget...of course
I know it is an odd ball of Honda motor...but it's a DOHC VTEC...and on top of all motor is motor; wether it's a black sheep or common, if you can get it to run right then it'll be a good challenge for yourself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">on a budget...of course
I know it is an odd ball of Honda motor...but it's a DOHC VTEC...and on top of all motor is motor; wether it's a black sheep or common, if you can get it to run right then it'll be a good challenge for yourself</TD></TR></TABLE>
haha yup budget for sure... im on a budget too. I got a first gen b16 that im swaping most of the parts. OBD1 distriburtor, AEBS intake manifold, GSR trans, etc so basically you would know its a first gen. ^_^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">the question is, why did you swap in the B17 GSR motor vs a B18c one?
b17 gsr = bad news (black sheep of the honda motor family)
<FONT COLOR="royalblue"> You're an Idiot!
B17a1 is a good power plant. 160hp w/ comp under 10 is good in alot of ppl's book. </FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CA6VTEC »</TD></TR><TR><TD CLASS="quote">
B17a1 is a good power plant. 160hp w/ comp under 10 is good in alot of ppl's book. </FONT></TD></TR></TABLE>
NOT enough books..... and your the idiot, people knwo the b17 is the blacksheep honda motor so shut it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">I saw the local post that you're selling OBD 1 GSR for a friend
yup.
</TD></TR></TABLE>yup.
NOT enough books..... and your the idiot, people knwo the b17 is the blacksheep honda motor so shut it. </TD></TR></TABLE>
<FONT COLOR="royalblue"> Instead of making fucktard comments, why not back up your statement w/ some proof? </FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 »</TD></TR><TR><TD CLASS="quote">i hate those damn secondary runners.......d16 all the way</TD></TR></TABLE>
Why did you even post this here?
c'mon guys motor is a motor...as long it can produce the power to your expectation then it a motor of choice...some people said that B17 is a black sheep because it not as popular as the B18C, and only in production between 92-93 as oppose to the B18C which widely availble from 94-00. B17 is basically the same as B18C just smaller displacement and lower compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HIStateEG6 »</TD></TR><TR><TD CLASS="quote">BTW I need an answer to my question not a comment on which motor is better</TD></TR></TABLE>
<FONT COLOR="royalblue"> Are you getting any CEL's? </FONT>
